Thread: Sharing DN and FTA on One DISH |
Bronze Member Username: 1tina_chick
Post Number: 45 Registered: Mar-06
| Posted on Tuesday, October 03, 2006 - 12:27 pm: |
" Sharing " a DN sub with a friend and a Cools*t + one Dave dish 2 LNB' s- well one double so that makes 3. Let's make all this cr*p work together, any Ideas. ? The Cools*t is on a switch to split the LNB's |
Silver Member Username: Nikk
Post Number: 312 Registered: Sep-06
| Posted on Tuesday, October 03, 2006 - 12:32 pm: |
Tina... Check the back side of the receivers for a "IF OUT" connector, if that exists just plug the other receiver right there..... |
Post Number: 47 Registered: Mar-06
| Posted on Tuesday, October 03, 2006 - 12:50 pm: |
Nikk is that the same as loop ? it's a male cable connector |
Post Number: 313 Registered: Sep-06
| Posted on Tuesday, October 03, 2006 - 12:52 pm: |
Yes it is the same..... |
Post Number: 48 Registered: Mar-06
| Posted on Tuesday, October 03, 2006 - 12:57 pm: |
Thanks Nikk, is support for cool 4000 dead..... do they want us to buy a new box ? |
Post Number: 314 Registered: Sep-06
| Posted on Tuesday, October 03, 2006 - 01:23 pm: |
Tina.... Maybe........ |
