Thread: 2nd DP34? |
New member Username: Npradar
Post Number: 1 Registered: Oct-06
| Posted on Monday, October 02, 2006 - 11:53 pm: |
I've been reading all night, and haven't found a clear answer yet. Here's my current setup: one dual dish pro lnb on 110/119 and one single dish pro lnb on 61.5 running into a DP34 switch. 2 outputs go to a dual dish receiver, other 2 outputs to 2 viewsat. Question: if I want to add 2 more outputs (one for dvb pci, and one for pansat) could I just add another dp34 to the pass thru from the existing dp34? Is there any power issues with this? If so, what would be best way to add at least 2 more outputs? Thanks |
Bronze Member Username: Fastbeatz
Post Number: 73 Registered: Sep-06
| Posted on Tuesday, October 03, 2006 - 12:02 am: |
post in Direct View TVs cuz satellite doesnt work it keaps erasing threads and this one will be erased too |
New member Username: Pungi
Post Number: 8 Registered: Mar-06
| Posted on Tuesday, October 03, 2006 - 09:03 am: |
DP34 has Three "trunk" connections, to "trunk" to another DP34 Switch. I think adding another DP34 is the best option. |
