Thread: Geo tv not coming on my dish?? |
Bronze Member Username: Kingusama
Post Number: 90 Registered: May-06
| Posted on Monday, October 02, 2006 - 11:02 pm: |
geo tv for some reason is not coming on my dish i have scanned my dish and everything but i can't seem to find it when i try 620 it just doesn't work... did the channel get moved or something plz help thanks in advance... |
Silver Member Username: Asharfi
Post Number: 137 Registered: Aug-06
| Posted on Tuesday, October 03, 2006 - 11:44 am: |
Are you getting B4U Music? |
Post Number: 91 Registered: May-06
| Posted on Tuesday, October 03, 2006 - 03:36 pm: |
yea only channel im missing is geo... plz help guyz |
Silver Member Username: Mc_sunny
Post Number: 364 Registered: Feb-06
| Posted on Tuesday, October 03, 2006 - 03:40 pm: |
try doing Blind scan |
Post Number: 92 Registered: May-06
| Posted on Tuesday, October 03, 2006 - 04:06 pm: |
i did man i don't know why it's not coming its reall y odd did they change the channel or something |
Post Number: 366 Registered: Feb-06
| Posted on Tuesday, October 03, 2006 - 04:12 pm: |
which reciever u have ??? |
Post Number: 93 Registered: May-06
| Posted on Tuesday, October 03, 2006 - 04:15 pm: |
pansat 2700 clone |
Post Number: 367 Registered: Feb-06
| Posted on Tuesday, October 03, 2006 - 04:36 pm: |
Do a factory reset, and then rescan your Sats....that should slove your problem..Good luck |
