Thread: Splitting signal to two receivers! |
Bronze Member Username: Suspect
Post Number: 21 Registered: Mar-06
| Posted on Monday, October 02, 2006 - 11:00 am: |
I am trying to get two receivers working on one LNB cable. I bout an amplifier to enhance the split but the signal seem to remain weak and the image and I can’t get the images. I’ve bought a cheap 1 in 2 out splitter, I also tried the expensive one and a regular one. Anyone would have and idea hot to get this thing running. 1 receiver is my BEV I think it’s model 3100(which I’m paying for) and the other is my ViewSat platinum. |
Bronze Member Username: Bones714
SO.California
Post Number: 77 Registered: Mar-05
| Posted on Monday, October 02, 2006 - 11:17 am: |
Bob those splitters wont work, your gonna have to use a LNB that has two outputs. One per receiver. |
Bronze Member Username: Mrmeat
Post Number: 87 Registered: Jul-06
| Posted on Monday, October 02, 2006 - 01:17 pm: |
use the loop out |
Post Number: 22 Registered: Mar-06
| Posted on Monday, October 02, 2006 - 01:32 pm: |
Mark i dunno what a loop output is |
Silver Member Username: Gunaa
Post Number: 135 Registered: May-06
| Posted on Monday, October 02, 2006 - 01:44 pm: |
You will find on back of your receiver
Post Number: 23 Registered: Mar-06
| Posted on Monday, October 02, 2006 - 02:09 pm: |
Thx i will try it when i reach home. |
