Home > Message Board > Home Video > Satellite TV > Archive through October 04, 2006 > Viewsat Extreme clone STC_ISP V31a h...
Author Thread: Viewsat Extreme clone STC_ISP V31a help!
Username: Phatsat
Can someone help, I have a clone extreme and have tried this fix once and it didn't work, when I tried it again I get this:
We are trying to connect to your MCU ...
Chinese:????? MCU/??? ???? ...
Connection is failure. You can try:
1.Give your MCU Power On Reset.
2.Stop operation, then re-select COM Port.
3.Because PLCC-DIP/PQFP-DIP Socket trace too long.
4.Update the STC ISP.exe version.
5.If still error, your MCU Firmware is error
or null.
Chinese:????,???????:
1.? MCU/???????(???,????,???)?
2.????,???? RS-232 ??, ?????
3.? PLCC?PQFP ????????????????,??????
4.????????? STC ISP.exe ???
5.??????,?? MCU/????? ISP ?????,
??????,? MCU ????
?????, ?? MCU ??...
I tried on different computers and same result, I can't blame the cable since it works fine on loader2. I made sure the jumpers are to the right. Any idea's. I currently have Bin V2068 and it is working but would like something newer that works without the 0000.
Thanx
Username: Icekilla0388
Toronto, Ontario
Post Number: 132
yea i got the same thing on my clone, so i took it to a sattelite store and he traded me in my clone plus 60$ for a real extreme, u should try something like that bcuz these clones are not worth the hassle
Username: Mikek
Post Number: 12
Shivas, Is this sattelite store in toronto at methson drive
Username: Mikek
Post Number: 13
Username: Tvtech3
Post Number: 123
where do u get this STC ISP at?
Home > Message Board > Home Video > Satellite TV > Archive through October 04, 2006 > Viewsat Extreme clone STC_ISP V31a h... [ « Previous ] [ Next » ]
