Thread: N o signal |
Bronze Member Username: Charjam
Post Number: 15 Registered: Sep-06
| Posted on Sunday, October 01, 2006 - 08:47 am: |
I am losing a lot of channels this morning . Is anyone else having this problem . It says no signal ( a&e amc espn and others) |
Bronze Member Username: Cable
Post Number: 51 Registered: Aug-06
| Posted on Sunday, October 01, 2006 - 09:07 am: |
do u blind scan and u ll get em back |
Post Number: 16 Registered: Sep-06
| Posted on Sunday, October 01, 2006 - 09:14 am: |
I just deleted all channels and did a blind scan on 7 and it didn't even pick them up . Have they moved these channels ??? |
Bronze Member Username: Xtrawest
Post Number: 22 Registered: Nov-05
| Posted on Sunday, October 01, 2006 - 09:40 am: |
Check your signal strength and also to make sure no TP give the error message while doing to blindscan, if it does mean u need to fix the direction of ur dish |
Post Number: 52 Registered: Aug-06
works everything here ... probabely ur dish is moved see if u have a signal on echo 7 |
Post Number: 17 Registered: Sep-06
| Posted on Sunday, October 01, 2006 - 09:51 am: |
It could be the weather because it never quits raining here in the north east so when it does quit i am going out and make some changes But on some channels like CNN i have 75% But thanks for the info i app . it Thanks |
Post Number: 53 Registered: Aug-06
| Posted on Sunday, October 01, 2006 - 09:54 am: |
make sure ur auto roll is onn |
Bronze Member Username: Hailian
Post Number: 17 Registered: May-06
| Posted on Sunday, October 01, 2006 - 10:18 am: |
do blind scan and then power off the box and then power on...dont do power off from remote, just hook the cable off from the switch... |
Bronze Member Username: Cricpower
Post Number: 24 Registered: Jul-06
| Posted on Sunday, October 01, 2006 - 08:06 pm: |
I had a similar problem yesterday. Couldn't get the signal, but it was easy to fix in the end. I just disconnected the power for a couple of minutes and took out the satellite wire from the reciever. Plugged everythign back in and it was fixed. It's a simple solution but hope it helps |
Bronze Member Username: Bones714
SO.California
Post Number: 75 Registered: Mar-05
| Posted on Sunday, October 01, 2006 - 08:12 pm: |
I only have this problem with my Pansat 2700, all I do is power it on/off from the back side then shes back up again. |
Post Number: 18 Registered: Sep-06
| Posted on Sunday, October 01, 2006 - 08:28 pm: |
Thanks for all of the info . What i did i went out in the rain and put a diff. dish up a couple inches bigger and realighed the dish and got everything back . Thanks i also have a 2700 |
New member Username: Turtleman
Post Number: 10 Registered: Apr-06
| Posted on Monday, October 02, 2006 - 07:02 pm: |
my coolst5000 was working for 10min and then everything gone lost signal??????/ anyone know why??? how do i get it back..thank u..yes, i had the new bin 131??????? |
