Thread: ViewSat Platinum -no guide info and dup chanels |
Bronze Member Username: Suspect
Post Number: 17 Registered: Mar-06
| Posted on Friday, September 29, 2006 - 12:19 am: |
Ihave the Viewsat platinum and i've resently upload the program to get the chanels back(BEV). All my chanels seems to be back some are duplicates and i 'm just not able to get the guide after i did a factory reset and rescanned. Is there something I can do get the guide for my chanel... when i try option 7 for the "receive giude" it does not work. |
Silver Member Username: Donnie1973
Tennessee
Post Number: 468 Registered: May-06
| Posted on Friday, September 29, 2006 - 08:49 am: |
look around in the menus, there is a place for EPG hours. try that |
Post Number: 18 Registered: Mar-06
| Posted on Friday, September 29, 2006 - 09:48 am: |
i founf my problem. I was not using sat nimiq 1.## and i did no have my Sat on standard! thx anyway |
Bronze Member Username: Sml
Post Number: 13 Registered: Feb-06
| Posted on Friday, September 29, 2006 - 04:27 pm: |
pansat up. need help w/viewsat plat* where can I find the latest sat info channel info and hex file newbie w/viewsat! And do I need to put in factory bin afterwords. Thx 4 the Help! |
Post Number: 19 Registered: Mar-06
| Posted on Friday, September 29, 2006 - 04:32 pm: |
i friend sent me the .PGM file which i just uploaded and restarted. I'm a newbie at this too so hopefully someone can help you |
New member Username: Chiki
Toronto,
On
Post Number: 2 Registered: Oct-06
| Posted on Sunday, October 01, 2006 - 05:05 pm: |
hey im really new to this so i was wondering where can i get new keys or codes for when it goes down? and also Rob Ryes founf my problem. I was not using sat nimiq 1.## and i did no have my Sat on standard! thx anyway i think im having the same problem. where do i find this nimiq 1.## and how do i put it on standard? im so sry . but i would really appreciate your help =) |
Toronto,
On
Post Number: 3 Registered: Oct-06
| Posted on Sunday, October 01, 2006 - 05:06 pm: |
oops sry i mean . Bob Ryes |
Post Number: 20 Registered: Mar-06
| Posted on Monday, October 02, 2006 - 10:48 am: |
From the menu under installation I choose nimiq 1.## (## is cuz I don’t remember the number. I think it’s for me 1.82 but I’m not too sure) make sure your LNB is Standard and do you rescan. Again I’m a novice at this. |
