Thread: SOLO HISPANOS |
Silver Member Username: Canada_havana
High river,
Alberta
Post Number: 107 Registered: Sep-07
| Posted on Wednesday, October 31, 2007 - 08:13 pm: |
que paso que las llaves dejaron de trabajar,,, canada,,, |
Silver Member Username: Miami1130
Post Number: 268 Registered: Jul-06
| Posted on Wednesday, October 31, 2007 - 08:14 pm: |
LAS LLAVES SON LAS MISMAS PARA TODOS LOS RESIVER(NO IMPORTA LA MARCA) |
Gold Member Username: Juancho
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1580 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 08:17 pm: |
neox. por el momento desconecta su reciver y guardalo por una hora. en eso te posteare como se remedia eso.por que eso es una de lo que tienes que ha*cer. |
Silver Member Username: Pedrin
Post Number: 126 Registered: Apr-06
esas llaves no trabajan |
New member Username: Lilfred
Post Number: 5 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 08:18 pm: |
donde las puede ver perdon |
Silver Member Username: Nica
Matagalpa,
Matagalpa
Nicaragua
Post Number: 201 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 08:23 pm: |
fred las puedes ver en www.tvkeyz.com o puedes bajar el programa para generar la llaves vskey 2.5 en totalfta |
Gold Member Username: Nadadesat
Post Number: 1228 Registered: Jun-07
| Posted on Wednesday, October 31, 2007 - 08:27 pm: |
HOLA RAZA COMPADRE JUAN CAVAZOS QUE ESTA PASANDO, ACABO DE LLEGAR DEL WORK. DIGAME VAMOS A TENER TELE PARA RATO O YA SE ACABO EL BOLETO. |
Silver Member Username: Hector_castro
Post Number: 120 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 08:28 pm: |
alguien sabe si ya salieron los fix para pansat? |
Post Number: 6 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 08:29 pm: |
gracias eden pero no puedo abrir esa pagina, soy de mexico y no tengo señal en estos momenots ya llev mas de una hora asi |
Gold Member Username: Javy_gza
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1133 Registered: Oct-06
weno le puse la keyz a manuela al dis h pero el bev si roleo con el bin 218 pansat 2700 a |
Post Number: 1229 Registered: Jun-07
| Posted on Wednesday, October 31, 2007 - 08:32 pm: |
KRISTINA PARA EL CAPTIVE WORKS REGULAR EL BIN 1.45 ES EL ACTUAL, PERO NO ROLEA LAS LLAVES. EL BIN SIEMPRE SE METE EN MODO STAND BY NO EN BOOT. EL CAPTIVE SE PUEDE PROGRAMAR POR PRIMERA VEZ EN LAS DOS FORMAS MODO BOOT Y MODO STAND BY. CREEMELO YO LO HE PROGRAMADO DE LAS DOS FORMAS PERO CON EL PASO DEL TIEMPO, EN EL CAMBIO DE LLAVES, CUANDO LO HACES EN BOOT EMPIEZA A FALLAR Y SI NO PARA EL RANCHO VAMOS. SALLUDOS. |
Gold Member Username: Tetuscosmicus
Post Number: 1629 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 08:37 pm: |
DISH Network (0101) [Last update: Tue. Oct 31, 6:50 PM] 86: D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0 96: 258D8F67F75FDF623D7A4D7CE7866190 New |
New member Username: Maguitosonrics
Post Number: 4 Registered: Oct-07
alguien sabe como en cuanto tiempo saldran los nuevos bins para las ViewSat Ultra? |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1581 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 08:38 pm: |
Para NEO X |
Bronze Member Username: Bocablandita
Post Number: 22 Registered: Sep-07
| Posted on Wednesday, October 31, 2007 - 08:40 pm: |
NIKK EVA BUENO NO LES DIJE QUE YO TENGO LA ENTENA ORIGINAL DE DISH OSEA YO PASO UN BAISCO DEL DISH PERO COMPRE ESA CAJA Y LA CONECTE A LA CONECCION NO SE SI POR ESO ES QUE ME SALEN LOS CANALES DOBLES |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 202 Registered: Dec-06
Fred que caja tienes para poder orintarte que acer? primero tienes que apagar la opcion de AUTOROLL dejarla OFF luego le ingresas las llaves manualmente. |
Post Number: 1231 Registered: Jun-07
| Posted on Wednesday, October 31, 2007 - 08:41 pm: |
KRISTINA MAS ATRAS ESTA UNA GUIA DE EVA PARA PROGRAMARLA Y OTRA QUE PUSE YO MEDIO REVUELTA. USALAS PARA PROGRAMAR EL CAPTIVE TE FUNCIONARA.} SALUDOS. |
Post Number: 7 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 08:44 pm: |
tengo el captive works y un viewsat lite |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 204 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 08:55 pm: |
MARIA FERNANDA que tipo de LBN tiene tu antena se a cual de estas dos se parece tu antena.
Silver Member Username: Titu72
Tecate,
Baja california
Mexico
Post Number: 102 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 08:59 pm: |
Hola saludos a todos alguien que pueda ayudarme con lo basico de un lavasat 3600ve clon de viewsat no se nada al respecto asi que cualquier informacion sera bienvenida muchas gracias |
Post Number: 121 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 09:00 pm: |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 205 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 09:15 pm: |
MARIA FERNANDA la razon de por que se te duplican los canales es por que tienes una antena DISH PRO PLUS estos LBN ya traen un switch interno y por lo que veo tu caja no funciona correctamente con este tipo de LBN, tendrias que cambiar de LBN por dos LBN singles y un Disecq, yo tuve ese mismo problema y cambie los LBN y haci corregi ese problema. |
| Posted on Wednesday, October 31, 2007 - 09:16 pm: |
ingrese las ultimas llaves que post hetor, apague el autoroll pero aun sale No Video or audio en la pantalla.. alguna idea?? DISH Network (0101) [Last update: Tue. Oct 31, 6:50 PM] 86: D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0 96: 258D8F67F75FDF623D7A4D7CE7866190 New |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 206 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 09:21 pm: |
Dish ------------01 01 00------------ D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0 25 8D 8F 67 F7 5F DF 62 3D 7A 4D 7C E7 86 61 90 Bev ------------09 01 00------------ 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2 |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 207 Registered: Dec-06
| Posted on Wednesday, October 31, 2007 - 09:25 pm: |
MAGO VARGAS despues de apagar el autoroll mete las llaves esas son las que estan funcionando y despues apaga tu caja con el switch de atras y luego la enciendes y te regresara la imagen. |
Silver Member Username: Neox
Tijuana,
Baja California
Mexico
Post Number: 113 Registered: Aug-06
| Posted on Wednesday, October 31, 2007 - 09:28 pm: |
Saludos nuevaminte a todos los F.T.Amigos del forum y el bien comun, y felicidades a todos los que hoy festejan la trdicion Celta DI A D E B R U J A S. Bien Juan Ramirezone Gracias; en un rato mas que se termine de enfriar mi VX le ago lo que me aconcejas y luego te comento si le pegue al gordo. Estamos en contac. P.D> Y para todos los que no llevan tradicion Celta, Entonces feliz dia de muertos. Y que E...G...A...D...U...los vendiga. (mensaj. sublinal)  |
Tijuana,
Baja California
Mexico
Post Number: 114 Registered: Aug-06
| Posted on Wednesday, October 31, 2007 - 09:29 pm: |
!!!!!!!!!!!HAAAAAAAA!!!!!!!!!!! FER...... HABLAME!!!!!!!!!!!!!!! |
Silver Member Username: Rober2154
Miami,
Fl
Usa
Post Number: 239 Registered: Jun-06
| Posted on Wednesday, October 31, 2007 - 09:33 pm: |
25 8D 8F 67 F7 5F DF 62 3D 7A 4D 7C E7 86 61 90 Estas son las ultimas!! |
Bronze Member Username: Alx_luc
Post Number: 12 Registered: Sep-07
| Posted on Wednesday, October 31, 2007 - 10:02 pm: |
Alguien me puede decir q esta pasando? |
| Posted on Wednesday, October 31, 2007 - 10:15 pm: |
ya funcionaron las llaves!! muchisimas gracias!!!!! a disfrutar la tele!! |
Miami,
Fl
Usa
Post Number: 240 Registered: Jun-06
| Posted on Wednesday, October 31, 2007 - 10:23 pm: |
alejandro apaga tu autorrol y pone las key manualmente, hasta nuevo aviso !!!! ROBER MIAMI |
Gold Member Username: Jorge_luis
Post Number: 1102 Registered: Jul-06
| Posted on Wednesday, October 31, 2007 - 10:33 pm: |
Alejandro Santana.- AQUI ESTA LO QUE ESTA PASANDO ----------------------- Escrito por Lionel Remigio miércoles, 31 de octubre de 2007 Dish y Bell sacan del aire los autorolls. A obscuras de nuevo . ?Mas de lo mismo? En horas de esta tarde de Miercoles, dia de Halloween en USA, un masivo ECM dejo a los equipos FTA piratas sin television. O deberiamos decir sin "autoroll". Una vez mas. Para celebrar el llamado Dia de las Brujas, por todo lo alto. Los dos proveedores satelitales Dish Network y Bell de Canada lanzaron el ECM a la misma hora y como siempre, no se sabe nada aunque se afirma que ya hay "arreglos" para un par de marcas. Pero al parecer en ultimo ECM de Dish de la semana anterior ( no el de hoy) estuvo cerca de lograr su cometido segun muchos. Y es que hasta el dia de hoy con los "arreglos" existentes, existian ya muchos problemas en esos "fixes". Y el primer problema serio, lo tuvieron las Atmegas, y en segundo lugar los clones de Viewsat pero les explicamos mas a continuacion. Este reporte debia salir en esta noche, pero con el ECM de hoy pues adelantamos el asunto. Y habla de lo que sucedio con los "arreglos" de la pasada semana y los problemas de los coders en esa ocasion. ? Sucedera lo mismo con este ECM ? Ya veremos. Problemas con ATMEGAS. Con la "retirada" forzosa del famoso coder conocido como Lexus del panorama de la pirateria satelital en USA, los que dependian de tarjetas ATMEGAS para ver los canales pirateados de Dish Network sufren de problemas. Y aunque han salido archivos nuevos, estos estan plagados de problemas. Tanto para las Atmegas como para equipos FTA. En dias pasados, Lexus, uno de los coders mas famosos en el mundo de la pirateria satelital que "resucito" las tarjetas Atmega a la salida del Nagra 2, tuvo que retirarse bajo amenaza de Dish Network de ser demandado civilmente. Lexus accedio a retirarse y dias despues sucedio el ECM de Dish donde cambio la datastream. Y ahi comenzaron los problemas para las Atmegas. Varios coders trataron de remplazar al popular Lexus, y los ultimos en sacar los conocidos "fixes" o arreglos fueron para las tarjetas Atmegas. Pero al programarlas, muchos confrontaron problemas al ver que unos modelos de equipos funcionaban y otros no. Varios equipos de Dish como el modelo DN 6000 de alta definicion, no funciona con esos nuevos arreglos. Varios modelos del popular receptor 311, tambien se niegan a trabajar con la nueva tarjeta y han salido varias versiones del software y aun no se resuelve el asunto. ? Sera el final de las Atmegas? Muchos afirman que no y que eventualmente los nuevos coders encontraran la solucion. Otros afirman que la Atmega esta en el final de sus dias porque sencillamente si los coders no tienen ganancias de la venta de tarjetas y programadores, nadie trabajara de gratis. Mientras tanto, el canal Atmega de los IRC estan llenos de usuarios que manifiestan sus problemas sin que al parecer haya solucion para esos. Y como dijimos, hay muchos modelos de receptores que se niegan a trabajar con la nueva "solucion". Lo que sea estara por ver. Pero lo que es cierto es que las ultimas "soluciones" para Atmega dejan mucho que desear y han sido los ultimos en salir con una solucion para la pirateria que aunque trabaja para unos, no trabaja para otros. Receptores FTA tambien en problemas. Pero eso no es todo.Populares marcas de equipos que sacaron sus "bins" de pirateria, estan teniendo problemas tambien. Los ultimos BINS, no estuvieron pefecto en elultimo ECM. Todos tenian problemas. Unos no ven canales internacionales, otros equipos se congelan ( freezan) , otros no "rolean" bien las llaves, a otros se les pierden canales y a otros se les han apagado sus equipos ( como en los clones de Viewsat) y lo cierto es que aun , hay fabricantes que hasta el dia de hoy, no han podido sacar bines y sin dar razones. ? Quiere decir esto que el utimo ECM estuvo cerca de lograr su cometido y cerrar el "hueco" a la pirateria ? No lo sabemos. Los dias son los que diran cuan lejos estamos de ese final o cuan cerca, y si los famosos "coders' arreglaran los problemas que han tenido en esta ocasion. Pero si hay una cosa cierta. Y es solo nuestra opinion. Mientras existan personas que quieran seguir viendo television de gratis, mas tarde o temprano aparecera un coder capaz de hallar una solucion efectiva que trabaje sin problemas. Y tambien habra quien siga fabricando tarjetas Atmas y programadores o bines para equipos FTA. Es un asunto de demanda y oferta. Eso es, mientras los de Dish sigan empecinados en continuar con sus codificacion Nagravision que ha demostrado ser demasiado vulnerable. Mas tarde o temprano, esa solucion se encontrara segun algunos. Sencillamente, no hay quien acabe con la pirateria. Y como dice el editorial de Sateliteinfos del amigo Inaki Ferreras ( leanlo aca) , todo es muy sospechoso. Claro. Se trata de dinero y mas dinero. Dish Network jamas cambiara su codificacion Nagravision porque es inversinista de esa empresa.Dicho esto, es mas que obvio que la pirateria seguira. ? Cuanto demoraran los coders para sus "soluciones al ECM del dia de hoy, Dia de las Brujas? Esperemos a ver que sucede. SALUDOS............. |
Post Number: 1103 Registered: Jul-06
| Posted on Wednesday, October 31, 2007 - 10:38 pm: |
MENSAJE DE PREDATORS......... 31 DE OCTUBRE DEL 2007 (TARDE) ¡¡¡¡MAS CAMBIOS!!!! Los autorolls estan siendo atacados de una manera muy distinta a los ataques anteriores, ya que los cambios que se presentan estan siendo afectados en un digito. PERO LO PEOR ES QUE ES EN DIFERENTE DIGITO LO QUE DIFICULTA MAS EL HECHO DE _HACER UN PROGRAMA MAS EFECTIVO. LOS PROGRAMADORES ESTAN TRABAJANDO ARDUAMENTE EN LA SOLUCION DE ESTE PROBLEMA LES PEDIMOS PACIENCIA Y EN LA MEDIDEA DE NUESTRAS POSIBILIDADES LES TENDREMOS LAS ACTUALIZACIONES LO MAS PRONTO POSIBLE. SALUDOS................. |
Post Number: 1630 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 11:28 pm: |
!!!!!!!!BBBUUUUUUUUUUUUUUUUUUU!!!!!!!!!!! SSSSAAAALLLUUUUDDDDOOOOSSSSSS AAAMMMIIIIGGGGGOOOSSSSSS....... AAARRRIIIVVVVAAAA LLAAAAA RRRRAAAAZZZAAAAAAAAA... HHHHHAAAAAAAYYYYYYYYYYYYYYYYYYUUUUUUUUFFFFFFFFFFF.. |
Post Number: 1631 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 11:30 pm: |
MI FORTEC SIGUE BIEN... SOLO CON LA MANO...JEJEJEJE.. CLONCITO........ |
Silver Member Username: Rossyjess
Post Number: 126 Registered: Oct-05
| Posted on Wednesday, October 31, 2007 - 11:31 pm: |
solucion para los pansat 2700 y 3500 originales en ftabins.net |
Post Number: 1632 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 11:34 pm: |
SEGUIRA CAIENDOSE LA PROGRAMACION???????? ESTA DURO ESTO NO???????.... SALUDOS RAZAAAAA.... |
Post Number: 24 Registered: Sep-07
| Posted on Wednesday, October 31, 2007 - 11:35 pm: |
EDEN MAÑANA TE DIGO POR QUE YA HOY NO TE PUEDO DECIR ESTA MUY OSCURO Y NO LA PUEDO VER PERO MAÑANA EN EL DIA LO VERIFICO OK Y TALVES SI ES POR ESO PERO YO NO TENGO LA FACILIDAD DE ACER ESO DEL CAMBIO PUES YO VIVO EN UN 3ER PISO Y ES MUY DIFICIL PARA MI ASI QUE NO SE QUEDARA ASI NO SE... |
Post Number: 1633 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 11:36 pm: |
HAY QUE TENER PACIENCIA MIENTRAS SALEN LOS FIX....TRANQUILOS RAZZAAAAAA..... |
Silver Member Username: Nikk
Post Number: 102 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 11:39 pm: |
Ya salieron los fixes para algunos pansats....estoy probando el del 2700.. |
Post Number: 8 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 11:47 pm: |
hola amigos no puedo actualizar mi viewsat ni mi captive works ayuda ya la meti la keys y apague el autoroll y nada |
Post Number: 1104 Registered: Jul-06
| Posted on Wednesday, October 31, 2007 - 11:51 pm: |
A esta hora de la noche 9:45 pm ya salieron fix para estas marcas..... Conaxsat SkyView Neusat ExtremeView Pansat Satopia Spacestar Visionsat ----------------- y el captive A´PA......todavia no mijo y el viewsat A´PA......todavia no mijo...upssss ----que raro no creen??????? |
Post Number: 103 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 11:53 pm: |
Reportando.... Bin 219 para el Pansat 2700, roleo bien las llaves aunque tardo un poco...funcionando OK hasta el momento.... |
Post Number: 1232 Registered: Jun-07
| Posted on Wednesday, October 31, 2007 - 11:57 pm: |
YA SALIERON LOS DE MI PANSAT, BUENO HAY QUE DESEMPOLVARLO. 2700 A. SALUD COMPADRE JAVIER GARZA. |
Post Number: 1233 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 12:00 am: |
TODOS VAN A SALIR TODOS, YA SE LA SABEN RAZA, ES CUESTION DE TIEMPO. SALUD POR ESO HAY QUE TENER EL DE REFUERZO EL PANSON. SALUD. ES EL DE BATALLA. |
Post Number: 1234 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 12:02 am: |
LO MALO ES QE MI PANSAT NO ESCANEA TAN BIEN LOS OTROS SATELITES COMO MI CAPTIVE, PERO BUENO QUE LE HACEMOS. SALUD. |
Post Number: 9 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 12:06 am: |
no agarran las llaves mis receivers AYUDA |
Bronze Member Username: Dragon2006
Post Number: 55 Registered: Sep-06
| Posted on Thursday, November 01, 2007 - 12:07 am: |
Hola Hector: yo tengo una fortec l f ultr y no me esta trabajando por favor dime que programa estas usando por favor. |
Post Number: 1634 Registered: Nov-06
| Posted on Thursday, November 01, 2007 - 12:38 am: |
---ENRIQUE--- YO TENGO EL BIN 293t Y ESTA TRABAJANDO BIEN SOLO QUE APURA MANUELA...LE PONGO LAS YAVES A MANO...ESO SI BORRAR EL AUTO ROLL.. MAS ARRIBA ENCONTRARAS LA FORMA DE APAGAR EL AUTOROL----- |
Bronze Member Username: Huasausky
WANATOS,
XALISCO
Mexico
Post Number: 57 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 12:40 am: |
ya salio el bin para el cw600 premium en ftabins.net chequenlo y avisan, esperamos el del normal. |
Post Number: 1105 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 12:41 am: |
QUE FELICIDAD............YA ESTAN LOS NUEVOS BINS DEL _CAPTIVE _COOLSAT Y MIS TIGRES YA GANARON 3 GOLAZOS A 2 VS EL ATLAS Y LOS RAYADOS UPSSSSSSSSSS TODAVIA VA PERDIENDO 1 A 0 VS EL GUADALAJARA |
Post Number: 1635 Registered: Nov-06
| Posted on Thursday, November 01, 2007 - 12:44 am: |
----ENRIQUE--- www.expressfr.com 2500 Loader BL v1.4.0.0 Bin v2.94t -12 aout 07 ESTE LO ENCUENTRAS AQUI.. ESTE TE FUNCIONA IGUAL QUE EL ANTERIOR TAMBIEN ES POSIBLE QUE LO ENCUENTRES EN www.ftabins.net saludos y suerte..... |
Post Number: 1235 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 12:46 am: |
ASI ES MI COMPADRE MIKE YA SALIERON LOS DEL CAPTIVE, POR ESO A MI NO ME GUSTA PROFETIZAR, PORQUE DESDE QUE NOSTRADAMUS SE EQUIVOCO VALIO QUESO. LO MALO ES QUE YA SE ME VIENEN LOS AMIGOS. JAJAJAJAJAJAJJAJAA. ME VOY A PSAR UN RATO BUENO METIENDO BINES. SOBRE DE ELLOS. PERO COMPADRE MIKE SALIO EL DEL CAPTIVE WORKS PREMIUM Y EL DEL 800 EL DE LA MAESTRA EVA. EL TUYO PARECE QUE AL RATITO. EL 1.54 PARA EL PRMIUM Y EL 1.27 PARA EL PVR 800. SOBRE DE ELLOS. MIKE NO LE VAYAS A PONER UNO DE ESTOS AL REGULAR PORQUE SI NO LO MATAS. |
Post Number: 1636 Registered: Nov-06
LES DESEO SUERTE AMIGOS QUE ESTEN BIEN...... |
WANATOS,
XALISCO
Mexico
Post Number: 58 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 12:47 am: |
si alguien sabe en donde esta el del cw600s normal. se los voy a agradecer |
WANATOS,
XALISCO
Mexico
Post Number: 59 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 12:50 am: |
ya salio el del cw600s en ftabins.net saludos ernesto |
Miami,
Fl
Usa
Post Number: 241 Registered: Jun-06
| Posted on Thursday, November 01, 2007 - 12:54 am: |
http://www.future-fta.info/Forums/ PANSAT BINS !!! Muchachos |
Post Number: 1236 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 12:56 am: |
YA SALIO EL DEL CAPTIVE WORKS REGULAR EL 1.46 ES EL TUYO MIKE. |
Post Number: 1237 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 12:57 am: |
MIKE ESTA EN FTABINS.NET |
Post Number: 10 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 12:58 am: |
ya etsa en ftabin. |
Post Number: 1238 Registered: Jun-07
SOBREES COMPADRE MIKE CORRALE A PONERLO, YA SABE EL CAPTIVE SALE RAPIDO. |
Post Number: 1107 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 12:59 am: |
..... A DORMIR SE A DICHO, FELIZ SUEÑO A TODOS
Tecate,
Baja california
Mexico
Post Number: 103 Registered: Nov-06
Hola saludos a todos alguien sabe como poner las llaves a un lavasat3600ve urge su ayuda por favor
WANATOS,
XALISCO
Mexico
Post Number: 60 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 01:00 am: |
ERNESTO: TENGO PROBLEMAS PARA BAJAR EL BIN, ME LO PUEDES ENVIAR A MI CORREO |
Bronze Member Username: Lilfred
Post Number: 11 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 01:09 am: |
solo falta el viewsat lite Por cierto como quedaron las chivas |
Post Number: 12 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 01:11 am: |
dame tu correo ernesto yo ya baje el del captive cw600 normal |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 208 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 01:12 am: |
fred todavia no le metes las llaves al viewsat lite?? |
Bronze Member Username: Juniorcm
Hialeah,
Fl
Usa
Post Number: 48 Registered: Aug-06
| Posted on Thursday, November 01, 2007 - 01:14 am: |
alquien sabe si salio algo para la viewsat extreme y platinum y si salio donde esta por favor |
Post Number: 13 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 01:15 am: |
ya pero no jala ya le quite el autoroll y nada |
WANATOS,
XALISCO
Mexico
Post Number: 61 Registered: Aug-07
fred, soy mike mi correo es huasausky@hotmail.com |
New member Username: Solztk
Monterrey Guadalupe
Post Number: 1 Registered: Sep-07
disculpen pero queria ver si alguin me puede ayudar tengo un pansat 2700a y el gtarooam loader para pansat 2700a mi pregunta es que no me deja instalarle el bin que vi posteado aqui para mi caja solo me dice no file o failed algo asi ya e puesto el bin pero ahora no me deja y realmente es solo para mi uso y lo quiero para ahora las peleas de box si alguin me puede ayudar a algo que pueda gacer se los agradecere no le se mucho pero le muevo poquito gracias |
Miami,
Fl
Usa
Post Number: 242 Registered: Jun-06
| Posted on Thursday, November 01, 2007 - 01:16 am: |
ERROR; Donde conseguistes los fix Cools=at?????????????????? |
Silver Member Username: Shadow45
Mty,
Nuevo Leon
Mexico
Post Number: 135 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 01:18 am: |
Tarde pero aqui esta...el bin 217 no jalo, no rolea y no se ven los ppvs ni los cochinones... Por lo que postean hacerca de todos los cambios y como diria el celebre Yoda.."Clouded this FTA future is"...esperemos que salgan avantes los coders..... |
Silver Member Username: Lord_marius
Post Number: 286 Registered: Nov-06
| Posted on Thursday, November 01, 2007 - 01:21 am: |
alguien me puede si ya saleo el bin que esta haciendo autorrol y donde puedo bajar los fix para clones emigrados a pansat 2700???
Post Number: 14 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 01:34 am: |
hola eden mi correo es fredolavarria@hotmail.com |
Hialeah,
Fl
Usa
Post Number: 49 Registered: Aug-06
| Posted on Thursday, November 01, 2007 - 01:40 am: |
WANATOS,
XALISCO
Mexico
Post Number: 62 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 01:50 am: |
bin 1.46 de cw600s trabajando bien. gracias fred. |
Post Number: 1239 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 02:07 am: |
COMPADRE MIKE DISCULPE QUE NO HAYA LEIDO SU CORREO, EN QUE LE ENVIARA EL BIN, AL PARECER YA TE LO ENVIO FRED, ES QUE COMO ESTABA, METIENDOLE BIN A LAS CAPTIVE REGULARES Y PREMIUM DE MIS AMIGOS Y COMO SON CHORROCIENTAS, PUES ME SALI DEL FORO Y NO VI, PERO AL PARECER YA LO RECIBISTE. DISCULPA COMPADRE MIKE. FIJATEE ESTA JALANDO MUY BIEN ESE BIN 1.46. SALUDOS COMPADRE. |
Monterrey Guadalupe
Post Number: 2 Registered: Sep-07
| Posted on Thursday, November 01, 2007 - 02:10 am: |
los programas me los pasaron y los bines que le e puesto los e bajado de dscentral y me an funcionado pero de muchos foros free pero nunca avia consultado de esto ya que cuando compre el pansat me dijeron vete a esa pagina y bajate el bin de fabrica y luego el nuevo bin y funciono pero ahora no me deja ponerlo mi pregunta es que puedo acer para que me deje ponerlo de nuevo eso de el de fabrica si me funciono pero me dicen que es solo una vez y luego ya nadamas le pones el nuevo bin realmente no se mucho pero le muevo si me pueden ayudar se los agradecere en system information me aparece este (x-87bl api:75-2.17 boot ver:75 09.oct.2007) y descarge un bin nuevo que esta posteado aqui y dice que es para pansat 2700a el 219 no se pero si alguien me explica por favor gracias |
Post Number: 15 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 02:22 am: |
gracias eden eres grande fred |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 209 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 02:25 am: |
Por nada Fred para eso estamos para ayudar en lo que podamos. |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 210 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 02:35 am: |
LUIS ONTIVEROS que Loader estas usando para cargar el bin a tu pansat 2700 es la version v27.01 0 v27.02, el que tienes que utilizar el v27.02 posiblemente estas utilizando el loader viejo y Por eso no puedes cargar el nuevo bin. |
Mty,
Nuevo Leon
Mexico
Post Number: 136 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 02:40 am: |
Luis Ontiveros: si tu tienes el pansat 2700 todo lo que tienes que ha*cer es ponerle el bin mas reciente y que yo sepa sin necesidad de cargarle el bin de fabrica. solo usa el loader que es para la caja que tienes con el bin que es para tu caja y debe de funcionar. creo que necesitas poner mas detalles para saber que es exactamente el por que no te deja ponerlo, explica mas a fondo o tambien te recomendaria checar los archivos de este thread para mas info ha*cerca del pansat 2700a. suerte |
Mty,
Nuevo Leon
Mexico
Post Number: 137 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 02:44 am: |
Como dice Eden , se me paso ese detalle...el loader que necesitas para cargar en el pansat2700 es ese mismo v27.02, si no lo tienes puedes ir a www.ftabins.net, ahi por seguro lo puedes bajar. |
Monterrey Guadalupe
Post Number: 3 Registered: Sep-07
| Posted on Thursday, November 01, 2007 - 03:27 am: |
otra pregunta ya pude instalar el bin para mi pansat 2700a es el nuevo que postearon aqui el 219 pero ahora no me da quality y no e movido la antena esto porque sera si alguien me puede explicar gracias o tengo que orientar la antena otra vez pro pa donde jejeje bueno pos gracias y espero me ayuden adios |
Monterrey Guadalupe
Post Number: 4 Registered: Sep-07
| Posted on Thursday, November 01, 2007 - 03:38 am: |
otra vez gracias eden y shadow45 ya lo pude instalar pero esta raro lo puse con el v27.02 y ya lo instale pero lo raro es que ya lo avia intentado con ese yo lo tengo y lo puse en la computadora mia y no me dejaba y luego pense que era el cable porque me marcaba error y lo puse en otra computadora que tengo y si se instalo pero ahora ya no me da calidad y la antena esta donde mismo no se si tenga que moverla pero enfin voy a checar pero si me pueden decir porque paso esto se los agradecere yo no se mucho de los satelites pero si tienen una duda en las computadoras con todo gusto les ayudare ese es mi mole gracias |
Bronze Member Username: Balcano
Monterrey,
Nuevo Leon
Mexico
Post Number: 94 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 03:58 am: |
Siempre aprendiendo de este magnifico foro !! tengo un lavasat 3200 lo converti en pansat 2700 y le puse el nuevo fix pero ya no roleo. Yo lo que quiero saber es donde le pongo la nueva llave ??? es decir el nuevo provider ?? saludos gracias |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 211 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 04:18 am: |
Ya estan los nuevos Fix para VIEWSAT en www.totalfta.com |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 212 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 04:32 am: |
LUIS ONTIVEROS no tienes calidad por que le pusistes el bin de fabrica eso borra toda configuracion almacenada en tu caja, despues de ponerle el nuevo bin tienes que configurar tu caja. |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 214 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 05:27 am: |
LUIS ONTIVEROS PARA QUE CONFIGURES TU PANSAT SUERTE
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1582 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 09:39 am: |
para los que van a ftabins, y buscan el bin para el pansat2700a. cualquiera de los 2 que estan posteados ahi trabajan igual.hasta ahora el bin de pansat2700a y extreme rolean muy bien. |
High river,
Alberta
Post Number: 108 Registered: Sep-07
| Posted on Thursday, November 01, 2007 - 09:45 am: |
ya comenzo la PAZ,,,,, QUE VIVA EL FORUM Y QUE DIOS NOS BENDIGA,,,, CANADA,,,, |
Bronze Member Username: Jpchavarria
Post Number: 97 Registered: Feb-07
| Posted on Thursday, November 01, 2007 - 09:51 am: |
ERNESTO O EVA o quien pueda ayudarme no puedo ver ningun canal en mi captive reg la barra de nivel sube a 80% y la de calidad no sube nada esta en 0% la pantalla de la tv se queda negra y aparece "señal debil" pero conecto mi mvidea en la misma antena y si funciona se ven los canales ya configure todo lo que me dijo ernesto y nada que puedo aser acabo de leer que ya salio nuevo bin el 1.46 con cual loader lo puedo subir otra cosa al poner el nuevo bin tengo que configurar todo de nuevo o no???????????? ayudenme por favor |
Post Number: 1108 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 10:29 am: |
Pablo Chavarria revisa que estes conectando el cable coaxial en donde dice lnb y verifica la configuracion de satelites, y el loader sigue siendo el mismo, aun no cambia. |
Post Number: 1109 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 10:47 am: |
y sigue funcionando el bochito jejeje, hace 40 minutos ya salio el bin JVVH_219 bin for pansat/2500 to 2700 |
Silver Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 358 Registered: Jul-07
| Posted on Thursday, November 01, 2007 - 11:05 am: |
Bin 152 para el co olsat y está funcionando: http://ftabins.net/forumdisplay.php?f=104 |
Mty,
Nuevo Leon
Mexico
Post Number: 138 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 11:47 am: |
ERROR el bin jvvh 219 ya es "clone safe and tested"? y en que webpage esta?....por que hace rato cheque en ftabins y no lo vi. |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1585 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 11:51 am: |
buscale bien que ahi esta. buscalo en la seccion de fortec, recuerda las web sites cambiasn el modo de postearlo |
Mty,
Nuevo Leon
Mexico
Post Number: 139 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 11:53 am: |
Ok, ya vi el que esta en ftabins y es para el FLU, ademas el tamaño del bin no corresponde a clones de pan2500 convertidos 2700.... No se si esta bien ponerle un bin mas pequeño a la caja, no soy tester y la neta no quiero empezar ahorita que no tengo otra de reemplazo. si alguien tiene mas info hacerca del 219....se los agradezco de antemano. |
Post Number: 98 Registered: Feb-07
| Posted on Thursday, November 01, 2007 - 11:54 am: |
error me podrias dar la configuracion de los satelites para ver si no me equivoque en algo te lo agradezco |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1134 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 11:56 am: |
saludos a toda la raza |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1135 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 12:07 pm: |
aqi leeiendolos veo q ia ai muchos masters jejjee eso es weno saludos. |
Post Number: 1110 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 12:10 pm: |
YA REGRESE DEL ALMUERZO..... Pablo Chavarria Configuración de satélites: Presionamos Menu Instalación Antena Buscamos el 119°W y configura así: Satélite 16. EchoStar 7 (119°W) Transponder 12224/V/20000/Auto LNB Freq 11250 (si es de DirecTV mexicano sería 10500) LNB Tipo Normal (si es DishPro seleccionamos OCS-DP) 22KHz Apagado Diseqc LNB2 (esto indica que es en el puerto 2 del diseqc) Legacy SW Apagado Motor Apagado Al tener configurado correctamente nuestros parámetros, damos un Auto Scan presionando el botón Azul de nuestro control remoto, esperamos a que termine. Buscamos ahora el 110°W y configuramos así: Satélite 22. EchoStar 6,8 (110°W) Transponder 12224/V/20000/Auto LNB Freq 11250 (si es de DirecTV mexicano sería 10500) LNB Tipo Normal (si es DishPro seleccionamos OCS-DP) 22KHz Apagado Diseqc LNB1 (esto indica que es en el puerto 1 del diseqc) Legacy SW Apagado Motor Apagado Al tener configurado correctamente nuestros parámetros, damos un Auto Scan presionando el botón Azul de nuestro control remoto, esperamos a que termine Y Presionamos Exit hasta salirnos de todos los menús SUERTE............... |
Bronze Member Username: Carloschempolo
Post Number: 52 Registered: Aug-06
| Posted on Thursday, November 01, 2007 - 12:17 pm: |
alguien sabe si ya hay programa para los pansat 2700 |
Post Number: 1111 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 12:27 pm: |
SHADOW45 lo unico que te puedo recomendar es que te esperes a que empiece la raza a postear como le esta funcionando el bin y ya despues tu decidiras si lo metes a la cajita. SUERTE..... |
Post Number: 1240 Registered: Jun-07
| Posted on Thursday, November 01, 2007 - 12:30 pm: |
PABLO CHAVARRIA QUISIERA AYUDARTE AHORITA, PERO VOY AL TRABAJO ME DESVELE ANOCHE MUCHO. YA ACTIVASTE EL PATCH. OTRA YA NO CONFIGURES NADA, NOMAS UTILIZA EL LOADER V1.06 Y EL NUEVO BIN 1.46, ESTO PARA METER EL NUEVO BIN. CREAMELO PABLO DURANTE LA NOCHE LE METI EL BIN A 53 REGULARES Y PROGRAME 10 VIRGENES DE CAPTIVE, NO ESTOY PRESUMIENDO. SI ME AGUANTAS EN LA NOCHE TE DIGO TODO. A VECES CUANDO NO SE VEN CANALES, HAY QUE APAGARLO DEL SWITCH TRASERO. OTRA ACTIVA EL PATCH, ESO SE HACE ASI: DA CLICK EN EL BOTON F1 Y EN EL DISPLAY APARECE UNA H, DESPUES METELE TRES CEROS 000, Y APARESERA UNA LEYENDA QUE DICE ENABLE. ESPERATE UN RATITO Y LOS CANALES SE VERAN. SI ME ESPERAS EN LA NOCHE, SI NO ES QUE EVA ENTRE O OTRO MAESTRO TE DIGA. HACEMS QUE VEAS CANALES. CON ESTE NUEVO BIN SE ESTAN VIENDO LS CANALES MAS RAPIDOS, NO HAY TARDANZA EN QUE ROOLEN LAS LLAVES. A LA MEJOR LO PROGRAMASTE EN MODO BOOT Y ESO DA MUCHO DOLORES DE CABEZA. USA SIEMPRE STAND BY, TAMBIEN PARA METER EL BIN. SON VARIAS COSAS QUE HAY QUE VER, SI ME AGUANTAS EN LA TARDE O NOCHE ENTRO, PORQUE AHPORITA VOY A TRABAJAR A LOS TRIBUNALES. SALUDOS. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1136 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 12:53 pm: |
weno baje el bin del pansat 2700 a pero lo tuve q bajar 2 veces xq el primero bajo muy rapido q es el mas reciente pero mide 100 kb y le tuve desconfianza . despues baje el bin de rossyjess y ese si esta completo 420 kb y x lo tanto le voia correr el de rossyjess . A el bin lo baje de ftabins saludfos. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1137 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 12:58 pm: |
saludos compa terror . al rato nos vemos tambn al sr lic ernesto m m q anda muy trabajador hoi jejeje saludos. |
New member Username: Manuel08
| Posted on Thursday, November 01, 2007 - 01:14 pm: |
Hetor, ya esta funcionando mi fortec, pero al scanear, solo llega al 55%, y no aparecen los ppv, algunos canales marca scrambled or bad channel, me podrias ayudar en esto, gracias. |
Post Number: 1112 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 01:25 pm: |
JAVY GZA GZZ SE ME HACE QUE ESTOY CIEGO, YO NO VEO NADA DE LO QUE TU VEZ------EVA SE NOS DESAPERECIO, NIKK ANDA CON MUCHO TRABAJO, PRFRMNJ ESTA EN FTABINS, JAIME PASTORA ESTA DE VACACIONES, ZORRO CRITICO ESTA EN INCOGNITA, JUAN RAMIREZ ES EL UNICO QUE ANDA POR AQUI. EL QUE MUCHOS DE NOSOTROS SEAMOS GOLDMEMBER NO GARANTIZA LA MAESTRIA. AL CONTRARIO SOLO DEMUESTRA LA CANTIDAD DE SPAM POSTEADAS POR CADA UNO. SALUDOS---------ATTE.- EL CIEGO JEJEJEJE |
Monterrey Guadalupe
Post Number: 5 Registered: Sep-07
| Posted on Thursday, November 01, 2007 - 01:29 pm: |
gracias eden por la explicacion pero ya le hice eso y nada sigue igual porque cuando tenia el bin pasado me daba buena señal y ahora con el bin 219 no me da señal y no hace blind sacan asi que le puse la de el chanel master para que me dejara los canales pero nada igual no signal y la antena esta igual no la e movido esto a que se debe si alguien le a pasado lo mismo y pudo arreglarlo se lo agradecere y sobre el bin que postearon del pansat 2700a el 219 yo se lo insatle el de 470kb pero me hizo esto de no darme señal no se pero igual suerte ayuda por favor |
Monterrey Guadalupe
Post Number: 6 Registered: Sep-07
| Posted on Thursday, November 01, 2007 - 01:35 pm: |
para el pansat 2700a esta el bin 219 yo lo baje de aqui mismo y de dsscentral luego pansat 2700a y te dice el mas nuevo (ojo) bajate el que este mas cargado porque ay varios suerte yo lo instale y lo agarro pero ahora no me da señal pero al rato a ver que puedo acer suerte a todos |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 215 Registered: Dec-06
Luis checa si conectastes en el lugar correcto el cable que viene de tu antena al recibidor posiblemente lo conectastes al LoopOut tiene que ser en Dish In o If In |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1138 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 01:50 pm: |
This is the latest Bin for Pansat 2700a. I do not know if it is clone safe. Enjoy. By the way does anybody know a usb to rs232 converter that might work with my null cable for my Pansat receiver ? WARNING: Use all files at your own risk. File Type: zip Pansat 2700 X-87BL_071031_B75_219_api.zip (101.0 KB, 166 views) Reply With Quote este es el archuvo q te digo sr ciego digo sr terror jajaja . no te creas esty bromeando jejeje es de fta bins |
Post Number: 99 Registered: Feb-07
| Posted on Thursday, November 01, 2007 - 01:53 pm: |
gracias por la inf error y tambien a ti ernesto en la tarde no voy estar pero te agradeceria que me dejaras dicho y yo lo leo en la manaña gracias |
Matagalpa,
Matagalpa
Nicaragua
Post Number: 217 Registered: Dec-06
| Posted on Thursday, November 01, 2007 - 01:54 pm: |
JAVY GZA GZZ una Pregunta: El tamaño completo de un bin de pansat es de 420kb? por que de los Viewsat y Sonicview son aproximadamente de 1.6Mb y 1.2Mb respectivamete. 1Mb=1024kb Sera seguro ese bin tan pequeño?? Saludo |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1139 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 01:55 pm: |
asi es eden x eso lo de la desconfianza xq esta muy pequeno quiza xq sea nomas un parche pero x si las dudas beje el de rossy jess a ver como funciona lo q pasa q el bin de 101 kb acaba de salir ase 2 horas y el de rossy jess salio ase 14 horas y no se a q se deva . saludos |
Bronze Member Username: Luckas25
Eagle pass,
Texas
Usa
Post Number: 24 Registered: Sep-06
| Posted on Thursday, November 01, 2007 - 01:56 pm: |
no escnuetro el bin para el pansat 2500 convertido alguien sabe en donde lo ppeudo encontrar?? |
Monterrey,
Nuevo Leon
Mexico
Post Number: 95 Registered: Oct-06
alguien que me ayude ?? tengo un lavasat 3200 lo converti en pansat 2700 y le puse el nuevo fix pero ya no roleo. Yo lo que quiero saber es donde le pongo la nueva llave ??? es decir del nuevo provider ?? saludos gracias |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1140 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 01:59 pm: |
eden lo de los bins p los vwsat y sonic de 1.6 mb se deve a q son receptores con maior capacidad en algunas funciones x eso lo de mas kbs . saludos |
Tecate,
Baja california
Mexico
Post Number: 104 Registered: Nov-06
| Posted on Thursday, November 01, 2007 - 02:01 pm: |
Hola saludos a todos alguien sabe como poner las llaves a un viewsat extreme?
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1141 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 02:06 pm: |
juan manuel rdrgz ve a http://www.ftabins.nety en la pag principal ai esta posado asi JVVH219 le das clic y te manda a la swec de fyles maximus ve a nagra 2 y en el provider 0101 dish pon la s keyz y si no ve a fta bins y baja el nuevo bin jvvh219 e inst saludos. |
Moderator Username: Admin
Post Number: 2972 Registered: Dec-03
| Posted on Thursday, November 01, 2007 - 02:09 pm: |
This thread has been closed due to its long length. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1142 Registered: Oct-06
| Posted on Thursday, November 01, 2007 - 02:10 pm: |
a todos los recp convertidos a 2700 se les tiene q cargar el bin con est cargador |
