Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through November 15, 2006 > Cable to S-Video
Author Thread: Cable to S-Video
Username: Usuallysilas
Hi,
I wish to use my Sony plasma monitor as a tv, can I convert cable to an S-Video signal?
Regards,
Silas
Username: Titleist
Post Number: 13
If you have cable box that has an s video output you could run it from the cable box to the monitor in your case the plasma. If you have satellite I would be surprised if it did not have a s video output. You should be fine unless your cable is going straight from the wall to the tv
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through November 15, 2006 > Cable to S-Video [ « Previous ] [ Next » ]
