Thread: HDTV Box has 30 Volts on Chassis???? |
New member Username: Bobbyo
Post Number: 1 Registered: Sep-06
| Posted on Sunday, September 10, 2006 - 06:01 pm: |
I was running a better cable to my Explorer 3250HD box, and when I went to connect the new cable to the terminal outside, I got a little shock. When I disconnected the box from any inputs/outputs and put the meter to it, I got 30 VAC on the grounded parts of the unit (chassis, shielded cover on the line in etc.)...that doesn't seem good. I took the box back and got a new one. SAME THING! Has anyone else had this problem? Isn't this dangerous at worst, bad for equipment at least? I realize the current must be small, but last time I checked, grounded parts of electronics should not be hot... |
Silver Member Username: Formerly_fx
Dallas,
Tx
Post Number: 173 Registered: Mar-06
| Posted on Monday, September 11, 2006 - 06:36 pm: |
It isn't the box, it is the wiring to your outlet. You should call an electrician immediately!!! xvxvxvx |
