Thread: DISH VS. Time Warner |
New member Username: Solar07
Post Number: 5 Registered: May-06
| Posted on Wednesday, August 30, 2006 - 01:17 pm: |
I currently have Time Warner Cable. I live in Athens OH.I have had it in two different Apt.s now and I am sick of them. For the money I can get way more from Dish than I can TW. My question is are they better. Right now My HD channels are pretty amazing. However even after trying to rewire my entire place. My SD channels like regular HBO arent great. And channels like FX, FOX which I cant get in HD, and USA, and CBS. They all suck very badley. Very fuzzy. I now somewhere FX comes in good because when I download Niptuck from the internet its amazing quality but from my cable it sucks. And when you spend 3gs on a tv you dont want any fuzz ya know. So any comments are appreciated. Dish seems to have a $250 deal for getting there top of the line HD box right now so I am real close to switching, just want some feedback. Thanks |
New member Username: Gilthethrill008
Broussard,
La
Usa
Post Number: 10 Registered: Jul-06
| Posted on Sunday, February 18, 2007 - 10:40 pm: |
HD from any satellite provider is amazing. Dish or Direct doesn't matter. Dish has more HD channels, however. HD on Satellite is so much better than cable. Cable is a thing of the past. |
Silver Member Username: Tapeman
Post Number: 592 Registered: Oct-06
| Posted on Monday, February 19, 2007 - 10:11 pm: |
I would recommend Dish Network Friendly guide more HD channels than any provider However it will get more expensive than cable for multiple TV sets Whichever way you go make sure you order TIVO/DVR It worth it |
Silver Member Username: Cableguy
Somewhere on...
U.S.
Post Number: 959 Registered: Mar-05
| Posted on Tuesday, February 20, 2007 - 07:59 am: |
Brad~have you contacted time warner in your area to see if they can fix the picture quality issues? There is no need for you to rewire, it's their job to maintain the wiring. |
Bronze Member Username: Leonski
Post Number: 53 Registered: Jan-07
| Posted on Wednesday, March 28, 2007 - 05:28 pm: |
Dish seems to have better equipment for HD than DTV. The VP622 will even run 2 tv's (only 1 HD) and has an RF remote, so it'll work thru a wall. Check out CNET or maybe Epinions for user reviews. |
