Thread: Samsung DLP Digital Closed Caption Question |
New member Username: Stiffwood1673
Post Number: 1 Registered: Aug-06
| Posted on Saturday, August 26, 2006 - 11:48 am: |
Am real happy with my Samsung 50" DLP. When I'm using my Digital Cable Set Top Box, I am unable to access closed captions. Any suggestion on why this doesn't work? Thanks, Lou |
Silver Member Username: Fyi
Dallas,
Texas
Post Number: 820 Registered: May-05
| Posted on Saturday, August 26, 2006 - 12:02 pm: |
Greyed out...I'm guessing! You're using a component input to the set, which makes the set act like a monitor. The set expects the device connected to perform any added functions. Sucks doesn't it! I'm still looking for a way around it! |
Bronze Member Username: Turbo15479
Post Number: 40 Registered: Mar-06
| Posted on Saturday, August 26, 2006 - 08:19 pm: |
I don't have a Samsung but the brand of television should not matter. On my cable box (Motorola) I hit power and then menu and it puts me in the set up menu.I have the option of closed captioning on or off plus a few more settings for different things.I hope this is some help. |
Post Number: 2 Registered: Aug-06
| Posted on Sunday, August 27, 2006 - 07:44 am: |
Bob, you're correct. My work around is to send my digital signal through the S-Video terminals. This way I can get CC on all of the channels, including HD. Lou |
Post Number: 3 Registered: Aug-06
| Posted on Sunday, August 27, 2006 - 07:46 am: |
Correction, I meant "FYI" is correct. My cable box, which is a Pace, doesn't let me do call up my closed captions. Thanks, Bob and FYI. Lou |
Dallas,
Texas
Post Number: 823 Registered: May-05
| Posted on Monday, August 28, 2006 - 12:08 am: |
Louis, The only problem with that is that S-Video cannot pass HD signal. I'm not sure you are subscribing to HD on cable, but thought you would want to know. |
