Thread: Cleaning Plasma TVs |
Bronze Member Username: Tomcat
Allentown,
PA
Post Number: 60 Registered: Jan-06
| Posted on Saturday, August 19, 2006 - 10:12 pm: |
How do you clean plasma TVs? Any special brush, cloth. Do you use cleaning spray? Any Advise would help. |
Platinum Member Username: Project6
Post Number: 10036 Registered: Dec-03
| Posted on Saturday, August 19, 2006 - 10:21 pm: |
The recommendations for your particular plasma TV are usually in the owner's manual. A microfiber cloth seem to do the job quite nicely without the need for liquid cleaners. |
Allentown,
PA
Post Number: 61 Registered: Jan-06
| Posted on Tuesday, August 22, 2006 - 12:38 pm: |
Thanks Berny, I guess I have to read the manual. |
New member Username: Cleveland_plasma
Cleveland,
Ohio
Post Number: 8 Registered: Aug-06
| Posted on Thursday, August 24, 2006 - 10:33 am: |
look at Opti-Max cleaner. I was very impressed by how well this cleaner works. Streak free everytime. www.Opti-Max.com |
