Thread: DVD recorder w/ variable rec mode & chapt editing |
New member Username: Jmichaelp
Colorado Springs,
CO
Post Number: 3 Registered: Aug-06
| Posted on Sunday, August 13, 2006 - 03:51 pm: |
Recently found this site and have learned all of good info from all the contributors. I am looking to purchase a DVD recorder to record DVD-R’s and would like the following capabilities. The ability to clear and set the chapter markers before finalizing. Has variable record mode (I thinks this is call bit setting???) Any suggestions would be appreciated Michael in Colorado Springs |
Gold Member Username: Samijubal
Post Number: 2967 Registered: Jul-04
| Posted on Sunday, August 13, 2006 - 05:14 pm: |
You can't select where to put chapters on any DVD recorder with DVD-R discs, unless HD recorders will. There are some that let you set the increments, 5 min, 10 min, etc, but you can't insert chapters where you want. |
Colorado Springs,
CO
Post Number: 4 Registered: Aug-06
| Posted on Sunday, August 13, 2006 - 07:56 pm: |
some of the magnavox machines that I have used will do this. |
Post Number: 2968 Registered: Jul-04
| Posted on Sunday, August 13, 2006 - 10:01 pm: |
Magnavox doesn't do DVD-R. |
