Home > Message Board > Home Video > TV Basics > Archive through December 02, 2003 > Fuzzy text on my Mits WT-46805
Author Thread: Fuzzy text on my Mits WT-46805
I have noticed that text on the screen looks abnormally fuzzy when in a few situations:
-DVD: At the menu
-XBox: Text in general looks fuzzy
-PC: My Pc is hooked up via S-Video and when I play games, I can barely see what the text on the screen.
I have messed with all the settings I can find but nothing.
Is there something else I can do?
-Dustin
Derek
This is normal for Standard Definition televisions using S-Video. If your television has VGA, DVI or component inputs, try those. It should be as clear as a computer monitor. I have a 52" Proscan and the difference between S-Video and VGA is like night and day.
The S-Video, though good, has no where near the bandwidth as the three above mentioned connections. S-Video in interlaced, which means you are starting off with only half of the total TV lines being displayed at any given time.
Televisions with built-in line doublers look better but still do not approach true progressive scan inputs live VGA, DVI and progressive component.
Hope this helps.
Home > Message Board > Home Video > TV Basics > Archive through December 02, 2003 > Fuzzy text on my Mits WT-46805 [ « Previous ] [ Next » ]
