Thread: Sharp Aquos LC-37HV6U |
New member Username: Mkryan
New York,
NY
United States
Post Number: 1 Registered: Aug-06
| Posted on Sunday, August 06, 2006 - 10:56 am: |
I have just moved and hooked up my aquos - when i turn the tv on, I get an error message on the screen that reads "loss of sync". i can't do anything else with the tv. I have tried unplugging it, have checked the cables etc. does anyone know what this problem is and how to fix it? |
Post Number: 9425 Registered: Dec-03
| Posted on Thursday, August 10, 2006 - 02:29 am: |
How was it connected prior to your move? |
Silver Member Username: Ftalife
Post Number: 320 Registered: Jul-06
| Posted on Thursday, August 10, 2006 - 08:27 am: |
00.html,http://www.sharpusa.com/products/support/0,2309,,00.html sharp support site. |
New member Username: Justins
| Posted on Saturday, August 26, 2006 - 04:43 pm: |
I have an Sharp Aquos 32LCD with an external AVC System box. After working fine for a month, and then having moved it, it now will not turn on and the display flashes its red light. Does anyone have any clue to what this problem might be. I have read a number of similar complaints. |
New member Username: Lotech
Honolulu,
HI
Post Number: 1 Registered: Nov-06
| Posted on Monday, November 13, 2006 - 04:37 pm: |
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective. Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again). It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box. Hopefully, this will clear the problem. |
