Thread: Toshiba RD-XS32 |
New member Username: Ebay26
Post Number: 10 Registered: Jul-06
| Posted on Thursday, July 27, 2006 - 10:16 pm: |
i have one and i was wondering how do i dub from the hard drive to a dvd and what kind of dvd do i need to do this? thanks, matt |
Gold Member Username: Samijubal
Post Number: 2881 Registered: Jul-04
| Posted on Thursday, July 27, 2006 - 10:54 pm: |
DVD-R, DVD-RW. The manuals http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/dvdr.asp |
Bronze Member Username: Ebay26
Post Number: 21 Registered: Jul-06
| Posted on Saturday, July 29, 2006 - 01:51 pm: |
i bought dvd+r and dvd-r. when i put them in it says ( cheack disc it may be damaged physicaly or reqires cleaning? it does not need to be cleaned and isnot damaged? any clue on what it might be? thanks, matt |
Post Number: 2895 Registered: Jul-04
| Posted on Saturday, July 29, 2006 - 02:09 pm: |
You can't use + discs in a Toshiba. What brand and speed are the discs? |
Post Number: 22 Registered: Jul-06
| Posted on Saturday, July 29, 2006 - 03:20 pm: |
the dvd-r are 1-8x speed? they are r4.7gb/120min? thanks, matt |
Post Number: 2896 Registered: Jul-04
| Posted on Saturday, July 29, 2006 - 03:38 pm: |
What brand? There are a lot of garbage discs out there. |
Post Number: 23 Registered: Jul-06
| Posted on Saturday, July 29, 2006 - 03:43 pm: |
panasonic dvd-r disc? thanks, matt |
Post Number: 2897 Registered: Jul-04
| Posted on Saturday, July 29, 2006 - 05:04 pm: |
Does the disc packaging say made in Japan? If so they should be TY discs and shouldn't be the problem. Is the recorder new or used? |
Post Number: 32 Registered: Jul-06
| Posted on Thursday, August 03, 2006 - 12:32 pm: |
they are new disk. i call toshiba and they said that it needs new farmware and they are sending me the disk? thanks for all your help i will tell ytou how it turns out. thanks, matt |
