Thread: Audio problems with sdtv |
New member Username: Hexum
Post Number: 1 Registered: Jul-06
| Posted on Monday, July 17, 2006 - 12:49 pm: |
dunno if this is the right forum but ok ok i bought a philips 27'' integrated real flat sdtv with a atsc/QAM tuner..it says built in tuner that recieves and decodes digital broadcasts anyways here is whats up i get very clear video...and awesome sound...but on some stations i just get video and no audio any help? we have comcast cable(not digital) |
Bronze Member Username: 1movibuff
Post Number: 17 Registered: Jul-06
| Posted on Wednesday, July 19, 2006 - 08:26 pm: |
If you have just the basic/expanded package and some channels have these symptoms: no audio, may sound like a radio station or spanish speaking on an engish speaking channel. then your tv is set to SAP (secondary audio program) Check the owners manual to see where in the menu the SAP is located and turn it off. It may even be on the remote control. |
Post Number: 18 Registered: Jul-06
| Posted on Wednesday, July 19, 2006 - 08:39 pm: |
If you have just the basic/expanded package and some channels have these symptoms: no audio, may sound like a radio station or spanish speaking on an engish speaking channel. then your tv has SAP (secondary audio program)turned on. If you aren't sure how to find it, check the owners manual to see where in the menu the SAP is located and turn it off. This is the first thing I suggest you try. |
Post Number: 19 Registered: Jul-06
| Posted on Wednesday, July 19, 2006 - 08:40 pm: |
sorry for the double post |
New member Username: Wfld1863
Post Number: 5 Registered: Apr-06
| Posted on Wednesday, July 26, 2006 - 08:41 am: |
I had the same problem on all my digital channels from comcast through the QAM tuner. After a power outage, the TV went through a re-boot and the audio returned. Coincidence ? maybe , but worth a try, check your manual for re-boot instructions. |
