Thread: DVD Recorder good for editing |
New member Username: Johnny_falcon
Post Number: 1 Registered: Jul-06
| Posted on Monday, July 17, 2006 - 07:39 am: |
Hi All, I've just had the TVDrive from telewest installed which contains 2 hard drives for recording programs. I now want to buy a decent DVD Recorder but would like to edit the dvds before being burnt. I want the ability to remove commercials and extra bits from before and after the recording. Could anyone suggest a good priced DVD recorder, please. I'm not looking for one with a hard drive, unless this is essential for dvd editing. Any help gratefully appreciated. |
Gold Member Username: Samijubal
Post Number: 2852 Registered: Jul-04
| Posted on Monday, July 17, 2006 - 04:28 pm: |
You'll need a HD for editing, unless you use RAM or RW in VR mode, which will be incompatible with most players. If any of the material you've recorded on those hard drives is copy protected, you're going to have problems transfering the stuff to a DVD recorder. The same will happen with protected programs recorded straight to the DVD recorder's hard drive. |
Post Number: 2 Registered: Jul-06
| Posted on Tuesday, July 18, 2006 - 09:55 am: |
Thank you. Can you recommend a cheap DVD Recorder with Hard Drive that has good editing features, please? I'm not looking to record films or copy protected programs, just TV Series that I would want to watch over again. So I would imagine that I wouldn't need a very live hard drive. |
Post Number: 2853 Registered: Jul-04
| Posted on Tuesday, July 18, 2006 - 01:04 pm: |
I don't use a HD recorder, I edit on a PC. Any HD recorder will let you edit. Toshiba has the best picture quality I've seen. If any of the programs you are wanting to record are copy protected, you won't be able to record them without a stabilizer or time base corrector. |
