Thread: Reliable Web-Sites for Purchasing TVs |
New member Username: Abc213
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 16, 2006 - 12:48 am: |
I'm on the market for buying a new LCD, considering the Sharp Aquos LC45D40. What are the trustworthy web sites that you folks reccomend and any opinions on my choice of TV? Circuit City has it for $3200 and centraldigital.com has it for $2419, very tempting, assuming the 12month warranty still applies. Thanks for any help you can give. |
Bronze Member Username: Mvanmeter
KY
Post Number: 65 Registered: Jan-06
| Posted on Tuesday, July 18, 2006 - 02:44 pm: |
and if the budget site sells you a TV, how are you going to send it back for repair ? Will they still be there 18 months later if you have a problem ? Other than Crutchfield.com, I would buy locally for such a large purchase. |
Post Number: 2 Registered: Jul-06
| Posted on Wednesday, July 19, 2006 - 12:03 am: |
That's true but we're talking about a $600 saving. I guess the question is, is it worth taking a chance. But also, I thought that if a problem occures while the tv is under the manufacturer's warranty, then any authorized repair shop will handle the repairs. am I correct? |
KY
Post Number: 66 Registered: Jan-06
| Posted on Wednesday, July 19, 2006 - 08:00 am: |
OEM warranties are usually short and in the fine print of some, you have to purchase the TV from an authorized dealer (avoiding gray-market equipment) In the end, it is all a risk vs benefit decision, good luck |
