Thread: Circuit diagrams |
New member Username: Eddie6469
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 09, 2006 - 04:13 pm: |
Can anyone help???????? I need to get hold of the circuit board diagram for the Sony Wega 50" Rear Projector TV KF50SX300U After only 10 months the lamp broke, so i called for it to be replaced under the warranty, but when they took the tv away they said that TWO caps had blown and that is not covered by the warranty. So i need the diagrams so that i can buy new caps and put them in myself. Does anyone know where i can get these diagrams??????????? |
Silver Member Username: Formerly_fx
Dallas,
Tx
Post Number: 138 Registered: Mar-06
| Posted on Monday, July 10, 2006 - 05:26 pm: |
99% of the time you can tell a blown capacitor simply by looking at it. They will either well or blow up completely. xvxvxvx |
Post Number: 2 Registered: Jul-06
| Posted on Friday, July 14, 2006 - 05:04 pm: |
one problem...... i cant find the caps??????? |
Dallas,
Tx
Post Number: 142 Registered: Mar-06
| Posted on Friday, July 14, 2006 - 06:33 pm: |
Not trying to be mean but a circuit diagram will not help you if you can't identify a capacitor in the first place. xvxvxvx |
Post Number: 3 Registered: Jul-06
| Posted on Sunday, July 16, 2006 - 12:32 pm: |
But i do know where they have gone from i just dont know what they were this is my problem???????????? |
