Home > Message Board > Home Video > TV Basics > Archive through December 02, 2003 > DVD question
Author Thread: DVD question
Ok Im new to all this so my question is if I hookup my DVD to my TV with the red white and yellow cables, what the resolution difference of the yellow cable and a Svideo cable the sales men told me that the yellow is only about 240 line and svideo is like 480 what does all this mean to a novice.
Derek
They both have the same black and white resolution (brightness). The S-Video cable has higher color resolution. S-Video will have deeper colors, less noise in colors and less color bleeding. On most televisions S-Video will reduce "dot-crawl". Dot crawl is the little catapillar-like dots you see running around bold text on TV. Look at a news broadcast where there is red text on a white background or try going into your DVD players setup menu. Switch back and forth between S-Video and Composite. That's probably the best way to see the difference.
Hope this helps.
Home > Message Board > Home Video > TV Basics > Archive through December 02, 2003 > DVD question [ « Previous ] [ Next » ]
