Thread: Q Box for Sony Grand Wega 42" Rear Proj LCD |
New member Username: Dtolson5
Post Number: 3 Registered: Jun-06
| Posted on Tuesday, June 27, 2006 - 03:14 pm: |
My Sony had some problem a few weeks ago while we were on vaca. I turned it on and there were just uniform vertical stripes of different colors across the screen. Cannot change input, channel, nothing. Just on or off. Had a technician come out and said I need a new Q box. He said he had never seen anything like it and Sony asked him to send a picture. Now it's going to be about 4 more weeks before the technician can replace the part. They have the part in house. My question is just how difficult is it to replace? Is this something I can do myself? I am no electrical engineer, but I was a F-16 jet mechanic for a number of years. ;-) Is it a matter of plugging it in where the old one was, or is there some type of calibration that needs to be done? Thanks! |
Silver Member Username: Cableguy
Deep in the ...
U.S.
Post Number: 795 Registered: Mar-05
| Posted on Tuesday, June 27, 2006 - 03:37 pm: |
From my understanding of the Q box, I believe it is the main tuner assembly for your TV, if your TV has cable card access on it, it is also a part of the Q box. As for the complexity of changing it out, I've seen a few of them replaced and I wouldn't touch it with a 10' pole. |
