Home > Message Board > Home Video > DVD Players > Archive through July 29, 2006 > HELP....JVC XV-SA70.....says "no dis...
Author Thread: HELP....JVC XV-SA70.....says "no disc"
Username: Iajet
The unit is about 4 years and a month old. We have had no problems up until about a week ago. Load in a disc and push play, the unit says it is reading (which is normal) and then a few seconds later it says "no disc". Everyonce in a while if you have the patience you might get it to work. I have tried to test/reset the system with no luck. What do you think?
Username: Samijubal
Post Number: 2798
Clean the lens and spindle with a q-tip wet with alcohol.
Username: Iajet
David,
Electronics is not really my gig. I removed the housing to the DVD player, which exposed all the electronics and the "DVD player". When the DVD disc door is open I can see something that might resemble the lens. Is that the laser? I guess what I need to know is how do I clean the lens and spindle. Keep it simple please.
Thanks,
Stu
Username: Samijubal
Post Number: 2800
The lens is a plastic eye, the spindle is what the disc sits on. Usually it's easy to get to the lens to clean it, not always though.
Username: Iajet
Thanks David. I will let you know the results later in the day.
Thanks again,
Stu
Username: Iajet
Took the unit apart and delicately cleaned, but still doesn't work. Maybe needs new optics (time for a new DVD player). Thanks for your time.
Stu
Home > Message Board > Home Video > DVD Players > Archive through July 29, 2006 > HELP....JVC XV-SA70.....says "no dis... [ « Previous ] [ Next » ]
