Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > Direct TV vs Dish network
Author Thread: Direct TV vs Dish network
Newbie here, and was just reading some of the post. Is the hu stream down for direct tv and dishnetwork, or just direct tv. One of the other post seemed to indicate that you can still use the hu card on direct tv?
Cali777
the only thing still open on the hu is the audio stream you can get sound, but no picture...Dishnet is running strong..
With dish net still running, can the p3 or football player card be programmed to work with dish net?
Cali777
No different construction of card
This is a question in terms of the content between Direct TV and Dish. What are the main differences in programming?.....For instance, Direct TV has the NFL Sunday Ticket while I believe Dish does not.....other than that, I do not see any glaring difference. They have similar Latin channels, Sports Packages, PPV movies, HBO...etc. Does anybody know?
cali777
They both have the same channels well dish offers a few more nasty channels than dtv, it is just the way they have there programing packages setup which is different..
I AM CHECKING ON INFO ON PROGRAMMING A DISH TV
CAN ANYONE HELP WITH WHAT I WOULD NEED
I HAVE PROGRAMMED FOOTBALL CARD
I THINK I WOULD LIKE TO SWITCH TO DISH
ANY HELP WOULD BE GREAT THANKS
Username: Scarface
Is it true that Dish will also do the same thing as Dave did to us with the Hu??
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > Direct TV vs Dish network [ « Previous ] [ Next » ]
