Thread: LCD Buying Help |
New member Username: Dennis495
Post Number: 1 Registered: Jun-06
| Posted on Saturday, June 17, 2006 - 01:59 pm: |
Hello everyone! I'm looking to buy a HD LCD Television. I have a budget of around $1000.00. I know very little about the technology. I'm looking for something 30" or larger. Are there any HDTV's that are recommended in that price range for the screen size that I want? I've included links from some of the local stores in my area. Walmart has the best prices, but I'm not sure what I'd be getting. Any help would be greatly appreciated! http://www.walmart.com/search/browse-ng.do?search_constraint=3944&ic=12_0&ref=12 5875.244125+500920.4293837041&search_sort=4 http://www.bestbuy.com/site/olspage.jsp?id=pcmcat31800050030&type=category&_DARG S=/site/en_US/catalog/fragments/product/olslinelistingsortfilter.jsp http://www.circuitcity.com/rpsm/catOid/-12869/N/20012866+20012867+526+20012869+9 65/link/ref/rpem/ccd/categorylist.do |
New member Username: Mspearl
Post Number: 8 Registered: Jun-06
| Posted on Sunday, June 18, 2006 - 12:28 am: |
PC World says CRT televisions are more reliable than new technolgy televisions. If you check the cost of extended warranties, LCD televisions cost a lot more to warranty than CRT televisions. There are good and bad reviews on most LCD televisions, so picking a brand and model is almost impossible. I never buy extended warranties, but I will not buy any HDTV without a 4 year extended warranty. Good luck. |
New member Username: Pauln213
Corona,
CA
Post Number: 2 Registered: Jun-06
| Posted on Monday, June 19, 2006 - 08:09 pm: |
Stay away from Wal Mart's crap!! If you dont, you'll wish you had. I suggest saving up some more money and getting something for a little more money that will give you the image you are hoping for. $1,000 wont cut it. |
