Thread: EVA or someone...what's the pin code(4 digit) for a BEV dish with a Viewsat Xtreme |
Bronze Member Username: Redcore
Post Number: 11 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 03:44 pm: |
I need to know these 4 numbers to get started Johnny |
Silver Member Username: The_wank_artist
Post Number: 910 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 03:54 pm: |
Try 0000. that's the factory defauld. Here's the manual for the 2000 which is pretty much the same as the Extreme. You should read it. http://www.viewsatusa.com/VS2000-MANUAL.pdf |
Post Number: 911 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 03:56 pm: |
Or try one of these.. From Baba Kahn. Viewsat-0937-3570-2668 |
Post Number: 13 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 04:04 pm: |
Hi tyler,I have the factory manual already,problem is that i started a search channels from the nimiq 1 sat that is BEV and I dont get the info channel form BEV that is supposed to be fta...I am kind od block at that point... |
Post Number: 915 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 04:11 pm: |
If you are not getting true FTA then are you sure you're pointed correctly? Have you checked your antenna settings and what not to make sure the signal is getting to the box, or that the correct port is selected if using a DiSEqC switch? |
Post Number: 15 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 04:20 pm: |
yes the antenna is okay I use my BEV receiver each day with itand diseq is no cause I dont have one any ideas...the S = 79 for the nimiq 1 but I dont have any Q...what does these 2 letters mean,strenght and quality? johnny |
Bronze Member Username: Kjniceguy
Lethbridge,
Alberta
Post Number: 56 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 04:23 pm: |
Tyler can you Help Me..:P:P:P just wanted to Know..After i have Flashed the New Bin.. and set Default and set up Auto Roll.. Do i need to enter in Old Keys? beacause the ones there are Way Different than the Old Bev Keys |
Post Number: 917 Registered: Feb-06
Q = Quality. And without any you won't get any channels. Something is not right. You should go back and check your settings. Maybe the LNB type is not correct, or something else??? |
Lethbridge,
Alberta
Post Number: 57 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 04:25 pm: |
Signal strength is for Direction to Sat is lined up and Quality is for your Picture and Audio...higher % Better Picture and Sound , I Think |
Post Number: 16 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 04:26 pm: |
lnb is set universal,do you which is the one for the BEV dish normally used |
Lethbridge,
Alberta
Post Number: 58 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 04:27 pm: |
Nimiq 1 11250 Mhz |
Post Number: 17 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 04:32 pm: |
I have lnb high lnb low tp freq I play with these 3 and dont any changes in the Q wich should be those 3 value....i dont understand why it doesnt work like I said i just try back my BEV and everything is working fine........ |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 992 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 04:47 pm: |
"Provider ID" is 09 - 01 for BEV |
