Thread: PANSAT 2700A- BEV with no PPV or XXX |
Bronze Member Username: Kingyousuf786
Post Number: 14 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 03:33 pm: |
Hi, I have the pansat 2700a. All channels are working EXCEPT the PPV and XXX. Is there a fix in place, like a new BIN?????? If so do i need to reset the Pansat then unzip the bin and install??? |
Post Number: 15 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 03:35 pm: |
I have BEV and i think there is a BIN 272??? if so can i know where yo get it from??? |
Silver Member Username: The_wank_artist
Post Number: 908 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 03:36 pm: |
dsscentral*net. In the pansat section. register first if you haven't already. And book mark the page as you can get any other file you may need later. |
Post Number: 17 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 03:42 pm: |
so is it the BIN 272 i need??? do i need to a factory reset???? |
Bronze Member Username: Momenali
Post Number: 63 Registered: Jan-06
| Posted on Wednesday, June 14, 2006 - 03:49 pm: |
yes yes yes....yousuf, alselamo alicom you do need to reset to factory first then flash the pansat with bin 272 |
Post Number: 18 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 03:53 pm: |
salam so do a factory reset then power off and add the plug to the computer then unzip and install. then do the antenna and blind scan right????? did this work for you ???? |
Post Number: 66 Registered: Jan-06
| Posted on Wednesday, June 14, 2006 - 03:57 pm: |
yes you are correct. but you dont really install, you upload the bin to the reciver using a GTRom uploader for your pansat 2700. And yes all my dishes are working fine and well....good luck. |
