Thread: Primestar dish & lnb setup questions |
New member Username: Alpha11
Post Number: 1 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 09:59 pm: |
hello I am about to setup a new primestar 36”x 26” oval dish system am using a direct triple phase now and it sucks along with a pansat 2700 reciever my goal is to lock onto echo 8.6,7,and nimiq 1 so I have been reading a lot the primestar seems to be well recieved by people but the LNB's is what I am having trouble on I am thinking Invacom seems good, if someone could give my a little advice on LNB's and or switch's needed to make this happen I would appreciate the help thanks. |
Bronze Member Username: Hardrockstriker
Post Number: 98 Registered: Apr-06
| Posted on Tuesday, June 13, 2006 - 11:10 pm: |
I don't know much about primestar (aren't they defunct?), but without a toroid dish i doubt you'll be able to hit the two echos as well as nimiq from one dish. |
Post Number: 2 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 11:27 pm: |
true the toroid is a sick dish but also expensive too, I trying to do this in a cost effective way I was thing the primestar pan to is big enough to catch the signals and some good lnbs should work out I seen this on another site and thought it would be doable or if anyone else has any good setups please share thanks
