Thread: Pansat 2500a Clone HELP! |
New member Username: Kanthan
Post Number: 8 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:13 pm: |
I have a pansat 2500a clone receiver. the power is working ok, i hooked up the 9 pin cable, pluged the receiver and turned on the power. everything works great. opened the bl loader v.1.4 and tried to download the 277t bin file, i get the error message "write failed. er1" can any body here help me. thx in advan. |
Bronze Member Username: Bthitman
Post Number: 16 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:16 pm: |
Kanthan scream for LK he can help ! |
Bronze Member Username: Nickb
New York,
New York
Post Number: 43 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 08:26 pm: |
Hey kanthan... I also have a pansat clone. I used bl stb updater 1.3 but 1.4 is fine. BUT what I did is connect receiver (power off) to computer. Then ran the loader program...then selected the bin and the correct com port...then power on the receiver from the back...then at the first green light on the front panel..clicked Fix and waited for it to finish and for the receiver to reboot and go to a channel (so channel number shows up)...then I powered it off...disconnected the cables...and connected back up to tv and satellite feed. And this worked for me on the Fortec LU with 277T bin. |
New member Username: Cooljai
Post Number: 4 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:34 pm: |
Try to Select a diff comp port on the loader software, may be comp2 or comp3 on the loder. |
Post Number: 9 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:42 pm: |
i tried what u told me nick but mine doesn't work on mine. but thx anyway nick. |
Post Number: 10 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:44 pm: |
tried comp3, but didn't work. |
New York,
New York
Post Number: 44 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 08:58 pm: |
Ohhh still no luck huh... Sorry about that.. Maybe someone more knowledgeable can give us a hand here... |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 962 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 09:00 pm: |
Kanthan: Start again but first turn off the back button in your receiver. Lucky |
New member Username: Dancuban
Post Number: 9 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 10:01 pm: |
kanthan i don't know much but i hope this helps. 1 make sure your receiver power is off 2 connect the cable to the receiver and computer 3 open your loader and load the bin and select the com port on computer that correspond to the one you have for the receiver. 4 flip the power on on the receiver. as soon as you see the first bar on the receiver light up click fix on the loader and the downloading process should start. 5 after downloading is complete your receiver should reboot. just hook to your tv do a blind search an enjoy. remember the com port has to be the right one or you will get an error message hope this help you good luck |
Bronze Member Username: Coldgirl
Post Number: 20 Registered: Apr-06
| Posted on Tuesday, June 13, 2006 - 11:25 pm: |
Is this the first time you are using this cable? Happened to me...went throught 3 cables before the store finally sold me the right one. |
