Thread: Durabrand TV |
New member Username: Emeraldbay
Toronto,
Ontario
Post Number: 1 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:01 pm: |
I can't hook my DVD player which is a Norcent DP300 up to my Durabrand TV. Can anyone tell how to do that? Thanks so much in advance! |
New member Username: Mspearl
Post Number: 7 Registered: Jun-06
| Posted on Thursday, June 15, 2006 - 03:33 pm: |
I am not familiar with either of those brand names, but most tv's and dvd players have RCA jacks. The jacks are male on both ends and are colored red white and yellow. Plug one set in the 'out' on the dvd player and the other on the 'in' on the tv. Put the tv channel on 'input'. Good luck. |
New member Username: Vinni_bluesman
Tyler,
Tx
United States
Post Number: 1 Registered: Jul-06
| Posted on Tuesday, July 25, 2006 - 01:02 pm: |
I have a durabrand tv model #bh2004d and I lost the remote. I purchased an all 4 one remote as a replacement but none of the codes work. I even went online and got 10 extra codes from the remote manufacturer and none of them work. can anybody help me with the codes or some advice |
Bronze Member Username: Mspearl
Post Number: 29 Registered: Jun-06
| Posted on Tuesday, July 25, 2006 - 05:26 pm: |
Order here for $29.95. http://www.electronicadventure.us/durabrand_bh2004d.htm |
Gold Member Username: Samijubal
Post Number: 2873 Registered: Jul-04
| Posted on Tuesday, July 25, 2006 - 09:13 pm: |
If you mean One For All instead of All 4 One, and it's the 8910, get it upgraded over the phone. |
