Thread: I downloaded the bin file for ariza700 but............. |
Bronze Member Username: Ariza
Post Number: 41 Registered: Feb-06
| Posted on Tuesday, June 13, 2006 - 07:52 pm: |
I bought the NULL modem cable today and downloaded a bin for the first time on to my receiver, but.... I dont know how to work the NEW SETTINGS do i input the code in nagravision 2 or 1????? from what i know the code is: 71 9C 60 71 04 C1 39 AE < active 88 FF F0 5E D2 4C F3 FC < active Am i doing something wrong? I turned the EMU ON and all the autorolls are OFF. |
Post Number: 44 Registered: Feb-06
| Posted on Tuesday, June 13, 2006 - 07:57 pm: |
Do you HAVE to load the factory bin into your receiver? is it a must? |
Bronze Member Username: H_m
Post Number: 13 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 09:38 pm: |
from where did u get ur bin from?? which website did u go to download it??? can u explain to me exactly??? thnx |
New member Username: Big_easy
Post Number: 1 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 03:56 pm: |
Man this sounds similar, I too just bought the null cables yesterday and tried to download the latest Bin file. When I did I continued to get a message saying Flash Failed. So today I started over now I am getting an ERROR Message reads as follows Model Name Does Not Correct. When I open the loader 4.03 it says Ariza 700 then I click on the BIN file open it then I click on download I get this error message. Help would be much appreciated. |
Silver Member Username: The_wank_artist
Post Number: 913 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 04:05 pm: |
Jib: Nag 2. Turn the auto roll on and let it work (waiting for picture 10%) h.m. ftacentral*com Get all your shiz there. Jeff: Try a different loader. There are many different ones available. I think there is also BL loader and a GTRom one. |
Post Number: 2 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 04:19 pm: |
Ty, thanks I am totally new at this and hope with time I will be able to answer someones questions but in the meantime I am the one asking. Here is where I am at now. I now get the message as follows Flash Update Failed, suggestions?? |
Post Number: 918 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 04:29 pm: |
Mr Dunsmore (AKA : JD) Did you try a different loader? Are you sure you have the correct cable? Where did you get it from as it sounds like you got it after market? Using a USB port? If so, are your drivers correct. Even if they are the cable still may not work. We're having to make assumptions (and the saying goes when you assume you make an as$-of-you-and-someone-other-than-me) as you've tagged on your problem to Jibs and there may be differences that have an impact. Better to start from the beginning. |
Post Number: 3 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 05:07 pm: |
Ty noted and I will starting from the begging. JD |
Silver Member Username: Wakenbake
Post Number: 192 Registered: Mar-06
| Posted on Wednesday, June 14, 2006 - 05:18 pm: |
jd dont open bin files get loader ready click on bin file(bin file box on loader) new window will open double click on bin file stb model fills in on its own -asr3530 |
