Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Anybody has bin use with Jtag for For...
Author Thread: Anybody has bin use with Jtag for Fortec lifetime ULTRA
Username: Mrkvip
Phnom Penh, Kandal
Cambodia
Post Number: 20
Hey
Anyone has new bin that can use with Jtag (Fortec lifetime ULTRA).
Thanks!!!
Username: Lklives
Post Number: 3371
277T bin is safe!...and U asked this same question 10 already!
Username: Mrkvip
Phnom Penh, Kandal
Cambodia
Post Number: 22
Thanks, LK
but when I use 277T with Fortec lifetime Ultra.
It successful 100%.
but when I turn it on. ON light.
I know I did right (How to use bin).
It mean Recevier not working.
Username: Lklives
Post Number: 3374
scan the satellites...and reboot the receiver...BACK of receiver, power OFF, wait 4 minutes, power ON, turn to channel 300
Username: Mrkvip
Phnom Penh, Kandal
Cambodia
Post Number: 23
I can't turn on receuver. How come I can scan the satellites.
I did.(I mean I turn the power OFF)
I was waiting 30 minutes.
But receiver still not working.
But when I try another bin (03-18-2006).
It work.
Username: Lklives
Post Number: 3377
U are doing something wrong!...and U can scan using the old bin!
BTW...what bin is 3-18?
Username: Mrkvip
Phnom Penh, Kandal
Cambodia
Post Number: 24
Maybe I am doing wrong.
bin post on 3-18 use with Jtag.
X-85CS_060318_273T_GC_DN_BEV_RTN_TVE_4sec_api(N)-Full Jtag (1024kb)
But when I use DB9 it working.
Username: Lklives
Post Number: 3379
U upload the 277T bin the same way U upload the 273T bin...use BL updater BV 1. 4...that 273T bin had another file with it (a jtag file) for NO reason!...if U can upload 273T , then U should have NO problem loading 277T..but U must set the default key, after loading the bin...
menu
parental control..2nd pin 0000..go/scroll to bottom of screen and click on "set default key"...EMU- ON...now exit out and watch TV
Username: Mrkvip
Phnom Penh, Kandal
Cambodia
Post Number: 25
I have tow receivers.
One can use DB9, another one can't.
The one can use DB9 now is working.
But I want to fix another that use with Jtag.
Note : Bin Jtag can't use BL updater or GTLoader.
Username: Lklives
Post Number: 3382
Jtag is NOT a bin!...any 277T or 273T bin can use BL updater!...U are VERY confused about all this and this Jtag thing..
Jtag is taking off receiver cover, soldering wires and pins, making a special Jtag cable and running various programs like wall.exe....its nothing to do with bins or loading bins!...some gut posted a Jtag manual with the 273T bin and U are thinking they are all one bin...NOT TRUE!...2 seperate things!
Username: Mrkvip
Phnom Penh, Kandal
Cambodia
Post Number: 26
I know.
I mean when I used Jtag cable.
I can't use BL updater or GTLoader.
And Bin 277T can't use with Jtag or wall.
I try to bin several times. But still not lucky.
Thanks!!!
Username: Yab
hello i need help sorry i speak french because my english is not good
j'ai fortec ultra j'ai perdu les chaines ca fait 20 jours et je sais pas comment les avoirs j'ai un ordinateur un recepteur et un fil RS232 pour telecharger le nouveau programme mais je sais pas comemnt faire aider moi svp merci
Username: Giideh
Post Number: 17
mrkvip
u need IRDmem which is a boot file. u can find at al7hbar.com
Username: Giideh
Post Number: 18
jo my franch is terrible but here it is in englisf:
download 277T bin.
use a downloader.
hook up stb to computer
run downloder
select bin file (277T)
download from computer to stb
when download is complete.
remove stb
connect to satellite
set keys
dowload channels
voila... done
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Anybody has bin use with Jtag for For... [ « Previous ] [ Next » ]
