Thread: Needs help please!!! Fortec ultra |
Bronze Member Username: Lada
Montreal,
QC
Post Number: 28 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 04:01 pm: |
I already this tried!!! When I use GTRom Loader v3[1].35 with fill 277T, for Fortec Ultra,sink me message: UNknown file type? What I do wrong? Maybe I have problem with a ports COM1 or COM3 on my PC? Thanks. |
Bronze Member Username: Pakithegreat
Post Number: 17 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 04:23 pm: |
make sure you are using the bin. file, and not the rar. file |
Bronze Member Username: Dixon_buts
Moon Base Alpha 1,
Red Square
Mars
Post Number: 30 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 04:26 pm: |
paki man did you change your password? Remember the line hi i'm a paki? Still trying to guess it but i will. |
Moon Base Alpha 1,
Red Square
Mars
Post Number: 31 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 04:29 pm: |
You dick you're using a pansat bin not a fortec bin. Wrong software you need to use BL-Updater 1.4.0.0 |
Montreal,
QC
paki man... What is mean rar. file? |
New member Username: Dbledragon
Post Number: 2 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 04:43 pm: |
Lada, make sure the 277t file you downloaded is has an .bin and not .rar or .zip. Otherwise you need to unzip it before it can work. |
Montreal,
QC
Post Number: 32 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 04:46 pm: |
Dbledragon , Thanks, I will chek it! |
New member Username: Thakkar2000
Post Number: 3 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 05:17 pm: |
Lada http://dssftp.com/files/index.php?m=category&CATID=57 go thr..scroll to file 19...BL Updater.exe..use that. for me other BL updaters and loaders didnt work.however this one wored perfectly..and once again check if u unziped the files. |
Montreal,
QC
Post Number: 34 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 10:00 pm: |
bhavik , I can not download this file, I am not VIP member. |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 970 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 10:04 pm: |
www.winrar.com or www.winzip.com evaluation version is free do you need unzip the bin files before load with the GT loader program. |
Montreal,
QC
Post Number: 35 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 10:12 pm: |
Eva, I unziped it. |
Puerto Rico
Post Number: 972 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 10:30 pm: |
I meain if you have the message about type is your extension file the error but if you already unzip the files try with another loader, and download again the bin file. Reset your receiver (turn off back button) and start again, Lucky |
