Thread: Bev keys |
New member Username: Blackcove
Post Number: 6 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 11:29 am: |
does anyone knows the keys for bev and how do i input these keys in .helpppppppppppppppppppppppp |
Bronze Member Username: Nickb
New York,
New York
Post Number: 40 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 01:37 pm: |
Hey.. I think these are the new kes for BV. But what receiver are you using?? 86 D1 15 0C 8E 66 82 D9 80 90 A9 20 20 37 07 87 08 96 0C B7 0A F9 50 75 F3 5B 31 EC 79 97 5C D7 CE 1A |
Post Number: 8 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 02:17 pm: |
i have a pansat 2500a thanks |
New member Username: Rich728
Post Number: 1 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 03:35 pm: |
new keys for dn as of june 13 pansat receiver |
New York,
New York
Post Number: 41 Registered: May-06
| Posted on Tuesday, June 13, 2006 - 03:45 pm: |
Hey...I got this from a previous post... How to Update Public N2 Keys for Pansat 2500a 1. Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000 or 1668 2. Scroll down down to Nagravision 2 press OK. 3. On the Provider ID,it should read 0101 if not use your right volume button, then you will see dishnetwork right above the provider ID box. 0101 is for Dishnetwork Keys (BEV KEYS ARE 09 01) 4. Scroll down to key number box. 5. Make sure Nagravision 2 on the top left, and key # is 00, in the KEY DATA box, enter the new N2 key 86. 6. Make sure Nagravision 2 on the top left, and key # is 01, in the KEY DATA box, enter the new N2 key 96. 7. Confirm the N2 key 00 & 01 are correct, then press OK to SAVE the new key. The press EXIT a few times, and you will watching TV... ----------------------- key 86 D1 15 0C 8E 66 82 D9 80 90 A9 20 20 37 07 87 08 key 96 0C B7 0A F9 50 75 F3 5B 31 EC 79 97 5C D7 CE 1A |
