Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > LK i need your help!!
Author Thread: LK i need your help!!
Username: Scott919
i have a direct tv multi head (3lnbs) intergrated dish, how do i make the switch work with it? i know i read somewhere on here about using a signal booter or something to make it work. something about if you don't use it the intergreted head will only send the strongest sat signal out of it (119 i think) b/c the switch is in the head itself, you need to split of the sat signals and boost the singals from the others some how. Any ideas?
Username: The_wank_artist
Post Number: 889
Is this the thread you were talking about?
A discussion between Sarge and LK?
This one is Sarges solution, linked to the problem thread and discussion.
http://forum.ecoustics.com/bbs/messages/2/227700.html
Username: Lklives
Post Number: 3342
NO...he's talking about a phase 3 DTV dish...which are pain in the azz with FTA..
Username: Scott919
So LK no ideas on that on 3 DTV dish then? I am currently using a dish pro dish and i replaced the dual intergrated head with 2 single heads they work fine since they have their own outputs, but i want to add a third sat and i'd like it all on one dish.
Username: Lklives
Post Number: 3378
throw that phase 3 dish in the garbage!
Username: Raging_fisher
Post Number: 37
That's an excellent solution!! I use the same answer when I see my customers with MDG computers!!!
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > LK i need your help!! [ « Previous ] [ Next » ]
