Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Have a green - on screan after tryed ...
Author Thread: Have a green - on screan after tryed to flash c**lsat 5000 p.
Username: Cincy_jughead
Post Number: 24
I was trying flash and dog unpluged in middle now all I get on box is green -
any ideals
thanks
Post Number: 25
PS sorry for got : I tryed norm-123
Username: The_wank_artist
Post Number: 886
This isn't like one of those dog ate my homework things is it??
Did you try reloading the factory bin?
Is the box completely non responsive?
Did you try reloading the 123?
Did you kick the dog? (that would be wrong, and shame on you if you did)
Username: Evadelparaiso
Puerto Rico
Post Number: 925
If you kick your dog and the receiver do not response yet, kick again, kick twice is as run the bin twice, fix a problem in many case lol
Post Number: 27
the box is non responsive
thank you for looking at tread
i have ben looking at dss comm.
it never responded after unpluged
Puerto Rico
Post Number: 935
Do not turn on the light? do not turn on your receiver?
Post Number: 28
what do u mean
Username: Dixon_buts
Moon Base Alpha 1, Red Square
Mars
Post Number: 19
Holy horseshit batman! Did you try reflashing the pig? Does it respond if you try to reflash it. Will it take the factory bin?
Post Number: 29
no it will not
Username: Br0nzehand
Miami, Fl
Us
hello all, ok i tried everything(i think) before i post.. pls help ... i have panst 2700 i flashed with new bin download was completed and now i dont have nagravision 2 anymore???? pls help
Post Number: 31
do u have nag.2 option
Puerto Rico
Post Number: 938
enter the keysDish Network:
N 0101 00:
E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C
N 0101 01: (active)
71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC
IF all is fine in your hardware configuration, and you have the right keys reflash with 272v1 bin download at dss**tester.com before turn off the back button, and turn on again, set your receiver, put the keys and check again.
Post Number: 32
tony there is a tread all so about 20 treads down
my also help
Eva isgreat help
Miami, Fl
Us
thx 4 help
Mars
Post Number: 25
Try with the unit on holding the up channel and down channel buttons on the front at the same time the turn unit off from the back while holding the two buttons down. Switch the switch on the back on while holding the up and down channels buttons down. If that doesn't work you'll have to flash one c**lsat 5000 to another with a null modem cable. It was something in system settings on the master and the slave just has to be turned on. It has to be a null modem cable from box to box.
Mars
Post Number: 26
It was system settings, data transfer, firmware on master and use null modem cable.
Post Number: 33
dicksin thank you I will try that
I thought suppose to use straight thru cable
Mars
Post Number: 29
Null modem cable when flashing firmware from one c**lsat 5000 to another c**lsat 5000.
Post Number: 35
dicksin thanks
do u know any place I can find out any thing else
about problem I have
anyone thank you
Username: Lklives
Post Number: 3358
If U have green dashing lights--------...then U have night rider lights!...very simple!....the fix is a quick flash with an older bin, like the original factory or something VERY old....do a search here at top of page for Night Rider lights!
Username: Lklives
Post Number: 3359
here's the c*oolsat 5000 factory bin along with all the c*oolsat 5000 bins and loaders, including the latest 123 fix..
http://dsscommunity.c*om/forums/viewforum.php?f=158
Here is how to recover from the "Night Rider" (flashing lights):
1. Try re-flashing the factory boot/flash again using the below directions. That gives you FTA ONLY. Follow the above procedure.
2. Then, when that works use the latest flash to get the scrambled channels.
3. Download a channel list and/or do a channel scan on each sat.
4. When flashing, be sure to wait not only until is says done. But you need to wait until it reboots and actually goes to a channel number.
Here are a few tips if you are having difficulty flashing: loading a bin..
I would advise everyone to read a set up guide before flashing. But, since people have been having some problems, I have revised this to provide more detailed information. But this is not intended to be a substitute.
1. Make sure you use the proper serial cable for your receiver:
Most Fortec and Pansat use a straight through cable with DB9 females on both ends.
The Blackbird, Pansat 2700/3500 and some other receivers use null (crossover) cable, which crosses over pins 2 and 3.
2, With the power turned off, connect it to your computer and receiver using the serial connector. Use serial port #1 if you can.
3. If you do not have a working SERIAL port, you must install one or use a computer that has one. Usb ports do NOT usually work, except on rare ocassions with an adapter.
4. Use the appropriate loader.
5. Select the file. Make sure that it is the correct flash for your receiver.
6. Select the COM port your receiver is connected to. If you do not know, what it is try #1 first.
7. Enter the correct model name and number. Most Blackist updaters do Not require this.
8. Check off the correct function box. Your choices are boot, flash or channel list. To FLASH your receiver you would use FLASH. Most flashes do not require a separate boot; so do not load both separately.
9. Turn on the receiver power from the BACK switch.
10. As soon as you see the lights flash,very first light -- IMMEDIATELY press download. Timing is critical and many vary to 2nd or 3rd light. Be persistent, may take 50 attempts..
11. Wait until it COMPLETES and reboots.
Post Number: 37
LK thanks old friend
I am useing the 2.4 c**lsat pro loader is that correct I think that is one I used before it has been a while since I did this and at that I only done once
I got rid of fort*c trying to learn cools*t
thanks warthog
ps I know u know what is going on
Post Number: 39
LK thanks that fixed the problem but the 2.4 loader I had problem with
I had to use2.1loader
thanks again
also thanks to every one else
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Have a green - on screan after tryed ... [ « Previous ] [ Next » ]
