Thread: New bin 352 for pansat 3500 sd and EPG |
Bronze Member Username: Parranda
Post Number: 15 Registered: May-06
| Posted on Monday, June 12, 2006 - 09:54 pm: |
this bin is great it does wonders. thanks to all that made it happen. my question is. can i bypass the EPG loading screen when i first turn on the STB, or do i always have to click on a key after turning the stb on. thank you in advance. |
New member Username: Riffster
Post Number: 1 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 12:30 am: |
my nimiq has the same channels as echo...is the LNB fro nimiq the same as echo..11250? |
Silver Member Username: The_wank_artist
Post Number: 891 Registered: Feb-06
| Posted on Tuesday, June 13, 2006 - 12:37 am: |
2 for the price of 1. parranda, you can click exit during the load and it should bypass it. I've also heard that if you leave it alone it will clear after 30 seconds to a minute. Robert, Check your DISEqC settings in antenna set up, most likely not set to the correct port. |
Post Number: 2 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 07:54 pm: |
Tyler, thanks I knew there was something up. My channels also stop adding at 600. I used to be able to get to 800. What should the setting be? I live in chicago. does that matter? |
