Thread: Having Problem in Antenna setup ,NEED HELP PLZ |
Bronze Member Username: Mc_sunny
Post Number: 26 Registered: Feb-06
| Posted on Monday, June 12, 2006 - 06:23 pm: |
Hello Guys...i have Fortec ultra reciever.. when i go to Antenna setup i can't find 8.6 ku , but i did found 3ku which i scan it and working fine..dont know why this time there is no 8.6 ku can someone tell me wut i need to do ...Help me out Guys...Thanks |
New member Username: Sniper66
Post Number: 3 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 07:12 pm: |
i can't find it either |
Silver Member Username: The_wank_artist
Post Number: 881 Registered: Feb-06
| Posted on Monday, June 12, 2006 - 07:19 pm: |
Is it listed when you go to the installation menu, under satellite scan? If not: Select New under Edit TP/Satellite. Enter the new satellite name using the numeric keys. Enter the down freqency, symbol rate and LNB polarity. Exit. |
Post Number: 27 Registered: Feb-06
| Posted on Monday, June 12, 2006 - 08:02 pm: |
if i want to get 8.6 ku what i type ? |
Post Number: 28 Registered: Feb-06
| Posted on Tuesday, June 13, 2006 - 12:12 am: |
symbol rate and LNB polarity? |
Post Number: 885 Registered: Feb-06
| Posted on Tuesday, June 13, 2006 - 12:17 am: |
try the same as the 3ku you already have in the settings. I haven't dealt with Fortecs that often. If it's not working for you, maybe someone else knows. |
Bronze Member Username: Cincy_jughead
Post Number: 26 Registered: Apr-06
| Posted on Tuesday, June 13, 2006 - 12:22 am: |
I think that it is 3ku I haven"t had one in a while |
New member Username: Sc3119
Houston,
Tx
Usa
Post Number: 6 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 08:51 am: |
I want to go for a new additional receiver ? Any recomendations? |
Post Number: 29 Registered: Feb-06
| Posted on Tuesday, June 13, 2006 - 10:33 am: |
Thanks Tyler i try that but didn't work for me,where do i get the symbol rate and LNB polarity for 8.6 ku...is that on ur lnb ??? when i get that how do i enter them and wut i do next??? |
Post Number: 34 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 11:08 am: |
bump |
Gold Member Username: Lklives
Post Number: 3414 Registered: Jan-06
| Posted on Wednesday, June 14, 2006 - 11:19 am: |
U get it at..for the 110 satellite http://lyngsat.c*om/echo8.html BTW...this ENTIRE thread makes NO sense!...of course echo 8/10 is in the menu with the new bins!...its is NO longer echo 8/6 |
Post Number: 35 Registered: Feb-06
| Posted on Wednesday, June 14, 2006 - 11:41 am: |
oh i didnt know it is 8/10 now ..thanks Lk i will check that in my setting thanksssssssss |
