Thread: 277 bin help |
New member Username: Buzzman24
Post Number: 3 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 09:19 pm: |
I can unzip the 277 file but, it won't open. Can somebody help me. |
Silver Member Username: The_wank_artist
Post Number: 848 Registered: Feb-06
| Posted on Sunday, June 11, 2006 - 09:21 pm: |
you don't open it, the bin loader uses it to 'drop' it onto your receiver. save it to your computer and then use the downloader to load it to your receiver. you can get the loader at any dss site that has files. |
Post Number: 4 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 09:58 pm: |
ok thanks i got the black list updater loaded ..after i get the file in there do i push write bin ? thanks iam new |
Post Number: 858 Registered: Feb-06
| Posted on Sunday, June 11, 2006 - 10:01 pm: |
Sure. or download button. Whichever one is there. |
New member Username: Lada
Montreal,
QC
Post Number: 7 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 10:17 pm: |
buzz year, Where did you get the black list uploader? Thanks. |
Bronze Member Username: Electro99
Post Number: 75 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 10:22 pm: |
BUZZ WHAT EVER KIND RECIVER YOU HAVE MAN YOU SHOLD DOWNLOAD MANUAL FOR IT !!!!!!!!!!!!! THEN AND ONLY THEN TRY TO GIVE ADVISE TO OTHER PEOPLE I TRY TO HELP THATS IT ALL |
