Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Cool Sat 4000 Pro
Author Thread: Cool Sat 4000 Pro
Username: Hot_gurl
Kit, ON
Help, I loaded C:\COOLSAT4000_NORW_123_20060610.stb then did a blind scan but I still don't get much at all??? Do I still need to enter Keys??
Danka
Username: Electro99
Post Number: 61
dont do a blind scan try from begining ..
delette all channels do factory set up load the file and the make auto scan
Username: The_wank_artist
Post Number: 847
No, if you're getting channels then you have the right keys.
You can check the key page but they'll be the right ones...
Your dish may be out of alignment??
Go here and check some of the channels and their tp's. if your signal sucks on those tps, you dish is out of whack!!
http://www.lyngsat*com/packages/dish110.html
Username: Electro99
Post Number: 64
dont make a blind scan !!!!!!!!!!!11
Username: Qbee
Post Number: 42
check your dish settings. I think this file turns off your DiSeqC. It should be set to 1.0 or 1.0/1.1 depending on how you have your 110 119 dishes set up. Do another scan after you make this change - worked for me.
Username: Qbee
Post Number: 43
electopunk
Why not make a blind scan? More channels seem to come in this way. You can edit them and use them to fill in the holes of missing channels that you got from autoscan. I have every channel Charlie offers and more than is on their website.
Username: Chico
Post Number: 27
i also have a cs4000pro but after loading COOLSAT4000_NORW_123_20060610.stb i have intermiten signal. i checked signal strength at 92% and quality at 91% on both 119 and 110 sats but still signal comes and goes w/ "bad or no signal" warning and then picture comes back on.
my set-up is two antennas, one pointed at 119 port one in the disque-switch and the other at 110 port two.
is anyone else having this problem? is it a problem w/ the latest bin?
Username: Evadelparaiso
Puerto Rico
Post Number: 897
try reflashing if after run a new bin you cant find signal in channels or get listed all channels in some cases do you need reflash with the same bin.
Username: Tekomi_elhoyo
Chico
Was it raining?
Username: Chico
Post Number: 28
No it was not raining, but cloudy in southern california in morning and at night,but sunny during the afternoon. Typical weather in SoCal(Orange County). What the SoCal locals call June Gloom.
Username: Vlad_t
Chuck, where did you get COOLSAT4000_NORW_123_20060610.stb
If I'll get it, I'll help you out, promise!
Man help me.
Username: Y_t
Guys, I bought a receiver from one guy. That one does not have any brand name. Just it says Free to Air Digital Satellite Receiver. On the box, there is flower picture on the background and Three round. Two of them yellow and puple flower picture and middle round have cat picture. Anybody have idea about this receiver. He does not tell me all the details. I ask him many times, finall he said it is cool*sat colne. Then I ask what type of cool*sat, he does not tell me. So If anyone knows anything about this receiver, please post here. I want to find bin file too. He says file is not release. Please help me
Username: Vlad_t
For Chuck\
From remote go to setup ==>Installation==>Turn of the autoroll
Exit and save the change
From the remote punch 8282
Then try
10 :E8 70 B0 0A 8E 0A 3D C5
11 :F3 59 C3 5F 1A DA 19 5C
20 :71 9C 60 71 04 C1 39 AE
21 :88 FF F0 5E D2 4C F3 FC
Exit and save
Enjoy!
Username: Vlad_t
To Dev Yog\
Give that trashbox back to your bady, keep your place clean!
Username: Chico
Post Number: 29
just wanted to thank everyone for the response on this post.
played around on the settings of the receiver and sure enough it was the the autoroll/tp that was causing the problem.
thanks anyway Vlad_t
Username: Vlad_t
Post Number: 7
Engoy guys! norw_123 for kulsat4OOO pro is here
http://www.d**central.net/files/index.php?act=view&id=1138
s=>*
Username: C2so4
What Kind of cable do I need to update the Bin? Is there a place i can find the process ... HELP PLEASE!!!
Username: C2so4
FOR COOL**T 4000 pro... sorry
Username: Vlad_t
Post Number: 8
To Anugar\
Check this out
http://www.gosatellite.com/
Username: Vlad_t
Post Number: 9
To Anugar\
Cable RS232C in any computr store
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2006 > Cool Sat 4000 Pro [ « Previous ] [ Next » ]
