Thread: I only have one channel |
Bronze Member Username: Zeusthegoose
Post Number: 11 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 07:44 pm: |
i upgraded my pansat 3500sd receiver and i only have 1 channel after i scanned what did i do wrong thanks in advance |
Gold Member Username: Lklives
Post Number: 3262 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 07:48 pm: |
there are a million things U could have done wrong...starting with not being aimed at the satellites! read the manual again! |
Post Number: 13 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 07:50 pm: |
my satellite dish has been aimed where its been for over 1 year its always worked |
Post Number: 3267 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 07:57 pm: |
well then U have a million minus 1 thing, to look for...its impossible to guess what is wrong! |
Post Number: 14 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 08:15 pm: |
i redid it and i cant find an mp3 file i doesnt say newhere that i have to download an mp3 file |
Post Number: 3274 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:18 pm: |
wow...U are very lost! |
Post Number: 15 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 08:20 pm: |
what can i say im right new i had this thing for a while and got pissed of with paying 8 bucks everytime it went down so im trying to figure this thing out myself |
Post Number: 3276 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:22 pm: |
8 bucks!...U were robbing the guy!...LMAO....U are cheap! |
Bronze Member Username: Electro99
Post Number: 55 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:25 pm: |
listen LK you should read the posts !!!!! |
Post Number: 16 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 08:28 pm: |
no but the guy that does it has everyone going to him hes the only dealer in town he makes a lot of money neways i dont have ne tv so im screwed people try helping me but i confuse them i dont kno what im talking about thanks for trying to help tho |
Post Number: 59 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:41 pm: |
hey you dont need the guy you can do it by your self !!!!! do step by step download the manual for your reciver then set up everything then upload file then scan and thats it but you have to spend some time to do it other wise spend some money for the guy who is gona charge you big buck for simple job I try to help that is all !!!! |
New member Username: Dixon_butz
New york,
New york
United states
Post Number: 1 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 08:45 pm: |
You must have done a factory default unless you haven't used that box in months. Delete all channels then rescan or or check your dish settings. Check disq settings likely 119 is one 110 is two. |
