Thread: Good info for cable |
Bronze Member Username: Sakapfet
Post Number: 35 Registered: May-06
| Posted on Sunday, June 11, 2006 - 06:54 pm: |
this is a copy and paste of a good info Null modem cable with db9 female to female connectors that allows a user to upgrade program file. connecting them to Pc via their communication port (rs-232 ports) Straight modem cable allows a user to upgrade program file from PANSAT & FORTEC receivers . connecting them to Pc via their communication port (rs-232 ports) i had that problem befor until i found out i had a wrong cable |
Bronze Member Username: Hardrockstriker
Post Number: 83 Registered: Apr-06
| Posted on Sunday, June 11, 2006 - 09:03 pm: |
The above is not necessarily true. You should check your receiver specs to find out which cable it needs. For instance, I have a Pansat 3500sd and it requires a null modem cable, contrary to what you have listed. And it's not called a "straight modem" cable; it's called a "straight through" cable. |
Post Number: 37 Registered: May-06
| Posted on Sunday, June 11, 2006 - 09:24 pm: |
straight through" cable. straight modem" cable is the same only different way to say something |
Post Number: 86 Registered: Apr-06
| Posted on Sunday, June 11, 2006 - 09:39 pm: |
Sorry, I have never heard of a "straight modem" cable. |
