Thread: Urgent-35 % complete.......pansat 2700 |
New member Username: Jafra
Post Number: 2 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 06:29 pm: |
I downloaded the new bin file for pansat 2700 the signal is strong ober 76% for satellite eco9/121 using a superdish. When I try to do a blond scan sometimes it freezes at 20%. I try again it stops at 35% and sometimes 46%,... Any one knows how to fix this ? |
Bronze Member Username: Hardrockstriker
Post Number: 85 Registered: Apr-06
| Posted on Sunday, June 11, 2006 - 09:08 pm: |
Failure to be able to do a scan usually means that you haven't got a good enough signal. Even though level is high, the quality could be low. Make sure you have at least 60% quality. If quality isn't the problem then re-download the bin and recheck your antenna settings. |
Bronze Member Username: Tadon
Dover,
NJ
Usa
Post Number: 27 Registered: May-06
| Posted on Sunday, June 11, 2006 - 10:14 pm: |
Assume you system is worked before Key&Bin change . So I thnik you are missing few steps after upload a new BIN to your receiver . Back to start from beginning : 1. Check your key , If key is not correct so do a correction. 2. Turn on your autoroll (because you did update a new one) 3. Do set up satellite and do scan (one by one) so it will work i hope that |
Post Number: 3 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 11:52 pm: |
Signal and quality is over 70% Autoroll is on Key is correct since I can get some channels The problem is when I do a blind scan for every sattelite seperate they do not finish. They freeze on 35% or so ! any other suggestions ? |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 877 Registered: May-06
| Posted on Sunday, June 11, 2006 - 11:59 pm: |
jafra reflash with the same bin. |
