Thread: Losing channels |
New member Username: Shagga23
Post Number: 6 Registered: May-06
| Posted on Sunday, June 11, 2006 - 04:48 pm: |
Some of the channels my reciever previously had before don't seem to display anything but a "waiting for picture" message. I also get this message: "scrambled or bad channel" How can i fix this problem, and recover my channels? |
Bronze Member Username: Electro99
Post Number: 47 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 05:09 pm: |
what reciver you have what sattelite you wanna get etc.. etc... |
Post Number: 7 Registered: May-06
| Posted on Sunday, June 11, 2006 - 05:12 pm: |
I have a pansat 2500. |
Post Number: 48 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 05:28 pm: |
ok i used to have pansat 2500a its a piece of s..t i could get only dn 110 on it no 119 to got both sats you need to have dish 500 that is what i know maybe you im wrong couse i have cools@t 5000 works diferent way but the best way if you are new to this download the manual how to set up your box the right way and key ripper program then some times you have to scan sattelite diffrent way to get the channels you wanna get. the best way to learn its to play with your reciver and read a lot of post ... Good luck .. and sorry if i did not help you !!!! |
Post Number: 8 Registered: May-06
| Posted on Sunday, June 11, 2006 - 06:08 pm: |
I've borrowed a koolsat 4000 and get the same results. What are the latest keys for dish? (n2) that could be the problem. |
Post Number: 49 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 06:27 pm: |
for dn E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC they did not change since 05.24.06 Get the key ripper program!!!! |
New member Username: Luuking555
Post Number: 1 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 06:46 pm: |
any body know the bin# or to get 2500 panasat working?my box is not working. |
New member Username: Shl
Post Number: 5 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 07:08 pm: |
Bin 277 |
Post Number: 50 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 07:16 pm: |
you can find it on www.dsste.ter.com |
New member Username: Babayoung
Post Number: 4 Registered: May-06
| Posted on Sunday, June 11, 2006 - 07:18 pm: |
i lost some channel too after used X-87BL_060609_272_api_2 bin file for 2700. Anyone can help? |
New member Username: Ikki
CA
| Posted on Sunday, June 11, 2006 - 07:47 pm: |
I just loaded the latest NORW 123 and I do have most channels, but still dont have PPV and some others. Besides applying the NORW 123, am I supposed to enter keys or run some key ripper program (like ones shown in previous message by electropunk) to get the rest of the channels? The ppv and several others show 'scramble channel'. |
Gold Member Username: Lklives
Post Number: 3264 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 07:52 pm: |
The coo*lsat 123 is an autoroll bin...U must turn it ON.. |
Post Number: 52 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 07:56 pm: |
what i see you have cools@t 5000 lkkl just load the bin do the auto scan and set up auto roll on thats it ... enjoy it!!!! |
CA
| Posted on Sunday, June 11, 2006 - 08:03 pm: |
Thanks electropunk. I have the koolsat 4000 pro. Before deleting channels and auto scanning, should I set up auto roll for ecostar, bev, and epg? I'm not sure what each of them do. |
Post Number: 54 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:23 pm: |
ok delete all your channels then make factory reset after that set upt everything on in options exept (sort by sid )then go to dish seting and auto scan 110 119 for DN and 82 for belll,,,,, after that you should get everything!!!! |
New member Username: Inox
Vancouver,
Bc
Post Number: 2 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 08:29 pm: |
Hi, I have a pansat 2700. Downloaded the new bin (..272). Was receiving all channels till today morning (have 2 sats 61.5 and 119). Now unable to receive a few channels especially ESPN, ESPN2 and ABC, channels that broadcast the soccer games. Did the TP scans, blind scans etc. but still no luck for these channels. Does anyone else have the same problem? Perhaps the TPs for these channels have changed (did not find them at lyngsat) Any suggestions will be greatly appreciated. Thanks. |
Post Number: 58 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 08:35 pm: |
I'm not the pro but looks like DN still try somthing dont know i got cools@t 5000 yesterday my ppv freeze over for like 2 min and come back ask LT he should know !!!! |
Vancouver,
Bc
Post Number: 3 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 09:02 pm: |
Thanks electropunk. LK would you know of a fix for the missing channels? Few other channels both on 119 and 61.5 are also scrambled..thnx |
Post Number: 63 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 09:15 pm: |
lkkl you got it man ?????????????????? |
Post Number: 3283 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 09:18 pm: |
scans are the only thing that returns missing channels..autoscan etc..and yes turn ON all the autodetect TP and autorolls! |
Vancouver,
Bc
Post Number: 4 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 10:12 pm: |
Thnx LK. My TP autoupdate and autoroll are both ON. Blind scans, TP scans still dont help. Interestingly other channels at the same TP for echo 7 (119W)(for ESPN-12326(H), ESPN2-12268(H), ABC-12501(H)) as the missing channels do work. Not sure where the problem is. Should I try re-flashing the bin? |
Post Number: 74 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 10:18 pm: |
IF YO U HJAVE COOLS@T 5000 WHY YOU DOIN BLIND SCAN??????????????????? |
Vancouver,
Bc
Post Number: 5 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 10:21 pm: |
Electropunk, I have pansat 2700..(is is incorrect to do blind scan for this receiver?) |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 861 Registered: May-06
| Posted on Sunday, June 11, 2006 - 10:23 pm: |
jamali check the signal for each satellite, and try in advance scan, select all satellite and scan again. |
Vancouver,
Bc
Post Number: 6 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 10:58 pm: |
Thnx Eva. The signal (both strength and quality) for 119 (which relays the missing channels) are above 75%. In advance scan, I scanned all the frequencies related to the missing channels(12268-H for ESPN2; 12326-H for ESPN; 12501-H for ABC), the other channels at these freq work except for these listed (alongwith FOX)..STILL NO LUCK.. |
Silver Member Username: The_wank_artist
Post Number: 871 Registered: Feb-06
| Posted on Sunday, June 11, 2006 - 11:07 pm: |
This help? Some moves in preparation for the Baseball Super Regionals happened today (ANON) * ESPN Alternate (145) moved from tp 10 to 18 at 119° * ESPN 2 Alternate (146) moved from tp 18 to 10 at 119° * SPORT PPV channel (454) moved from tp 24 at 110° to tp 18 at 119° |
Vancouver,
Bc
Post Number: 7 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 11:32 pm: |
Hi, I finally decided to reflash my pansat 2700 with bin 272. All 3 missing channels are working (for now at least!!). Thnx for the suggestions. |
Puerto Rico
Post Number: 873 Registered: May-06
| Posted on Sunday, June 11, 2006 - 11:44 pm: |
Nice Jamali, enjoy. |
