Home > Message Board > Home Video > Satellite TV > Archive through June 12, 2006 > NEED HELP!!!!
Author Thread: NEED HELP!!!!
Username: Zeusthegoose
hey i need help on how to put the program i downloaded onto the sd card for my pansat 3500sd i already have it connected to my computer but im stumped can someone help me thanks in advance
Username: Evadelparaiso
Puerto Rico
Post Number: 854
REad this information:
Its c/p
Download Procedure for Pansat 3500S
1. Connect RS232 Null Modem(#2,3 crossed) cable between the receiver and PC.
2. Turn the receiver power ON.
3. Open the GTRom Loader (Pansat 3500S).
4. Click BIN FILE and select the Bin File to be downloaded.
5. Select FILE TYPE and click Download.
6. Do not interrupt the receiver power while downloading.
7. Press OK after Download Complete!! Appear on the PC screen.
SD MEMORY CARD OPERATION (Nov 30, 2005)
1. FLASH UPGRADE (SD CARD to RECEIVER)
a) Insert SD CARD into the receiver SD CARD slot.
b) Select SD memory at Main Menu and press OK button.
c) Select the Bin file downloaded from PC (Version code or CH data) and press OK button.
* * Enter CH Data Backup or Code Backup to find the files previously backed up from the receiver.
d) Wait until the receiver fully rebooted after writing completed (about 40 seconds).
2. FLASH BACK UP (RECEIVER to SD CARD)
c) Select Code Backup or CH Data Backup.
d) Press Red button and select YES then press OK button. Edit the file name up to
7 digits then select OK font and press OK button. Flash Backup will be started
and completed.
e) To delete backed up file, press “Green” button and select “YES” then press
“OK” button.
Note: MMC Card may be also interfaced.
3. MP 3 PLAY
c) Select MP 3 file downloaded from PC and press OK button.
d) Select the MP 3 file to play and press OK button.
e) For multiple MP 3 play, use left/right volume buttons to select or cancel the files to play. All selected files ( up to 20) will be played one by one
Where can i get a loader?¿
Puerto Rico
Post Number: 856
dss***tester.com remove *** download area. LUcky
ok i have followed those instructions but all i get is the main menu im stuck
Puerto Rico
Post Number: 858
Pansat 3500 REprograming
How to Load and Save Files to the Pansat 3500S
3500 - THE SD/MMC WAY:
Insert virgin SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Note: Receiver will automatically create 3 directories on the card:
CH Data Backup
Code Backup
MP3
(For Virgin cards only -Take the card out at this point and load your unzipped bin or channel list file to the card in the appropriate directory. Now put the card back in and re-access via menu as stated above.)
Select bin file in appropriate directory, main directory, [ch data backup] or [code backup]
Press [OK]
Select [data restore]
Press [OK] to load, receiver will automatically load, confirm, then reboot.
TO SAVE DATA
Insert SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Select an appropriate directory, main directory, [ch data backup] or [code backup] by using [up or down arrows] and [OK]
Press RED button in left bottom corner of remote.
Name your file on the alphanumeric screen file by scrolling via [arrows] to next character and then pressing [OK] for each character or [del] to correct a character. To save selected name, press [OK] on the alphanumeric screen.
Bin File will then write automatically to the correct directory.
Size of files:
CH = 352 kb
Code = 768 kb
Use GREEN button (beside the RED button) to delete selected and unwanted
files.
http://forum.ecoustics.com/bbs/messages/2/224237.html
i understand that but i did all that already i turned off the reciever for 40 seconds turned it on and still nothing
Post Number: 7
thanks also
Username: Gsj
Post Number: 25
i have ariza700 reciever, i download new bin and i set up sat 61.5 and 119 and scan (because i did factory setting before) after scan both sats i got some of the channles around 150 channels working good,
but i didn't get all channels, i scanned double but i got same,not new channels.
how i get other channels? anybody help me please???
Username: Dixon_butz
New york, New york
United states
Post Number: 7
Use a real SD memory chip or one that's at least 40 times speed. Hit channel 8282 and scroll down to SD Memory. Click on OK then down channel buttons highlight the file click on OK and Restore. Use card reader and load to H drive. Shove card in receiver SD slot and turn receiver on.
Home > Message Board > Home Video > Satellite TV > Archive through June 12, 2006 > NEED HELP!!!! [ « Previous ] [ Next » ]
