Thread: Anyone missing HBO-E |
Bronze Member Username: Hawks134
Post Number: 31 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 12:39 pm: |
I have a Pansat 2500A on 110/119 and I am missing HBO-E. Any help? |
Bronze Member Username: Nickb
New York,
New York
Post Number: 25 Registered: May-06
| Posted on Sunday, June 11, 2006 - 02:26 pm: |
Umm..I\\'m using FLU and HBOE is working...but I had problem similar to that...one channel going bad or scrambled. I just turned it off and reloaded the epg again and it worked. |
Post Number: 32 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 02:28 pm: |
When I Sat Scan, it did not even show up. |
Bronze Member Username: Gsj
Post Number: 30 Registered: May-06
| Posted on Sunday, June 11, 2006 - 02:34 pm: |
help me have ariza700 reciever, i download new bin and i set up sat 61.5 and 119 and scan (because i did factory setting before) after scan both sats i got some of the channles around 150 channels working good, but i didn't get all channelslike ppv, disney, hbo,ect, i scanned double but i didn't more channels. how i get other channels? anybody help me please??? |
New York,
New York
Post Number: 27 Registered: May-06
| Posted on Sunday, June 11, 2006 - 02:44 pm: |
I just did a quick TP scan for echo 7 transponder 2 and HBOE is showing up in my scan and it seems to be working fine. I\\'m not sure why doesnt show up in yours. :S |
Bronze Member Username: Tinfish
Post Number: 30 Registered: Apr-06
| Posted on Sunday, June 11, 2006 - 02:49 pm: |
nick..is the new bin available for FLU? |
Post Number: 31 Registered: May-06
| Posted on Sunday, June 11, 2006 - 02:57 pm: |
hi nick can u please explain me how u did scan all i tried but i got only some channles like indian, some chinees not english ppv xxx and others. help me |
New York,
New York
Post Number: 29 Registered: May-06
| Posted on Sunday, June 11, 2006 - 03:01 pm: |
The 277T bin is the one I am using...and I think it is clone safe...so it can be used safely for FLU. I have been running it since yesterday evening and it is working. here the link to the file... http://www.hostclip.com/dl/5f1d674748891253245e2ab47f711f31 |
Post Number: 32 Registered: May-06
| Posted on Sunday, June 11, 2006 - 03:14 pm: |
i am using 277e latest downloaded yesterday from dsstester for ariza 700 my channels working very good but i didn't get all channels |
Post Number: 33 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 03:17 pm: |
Do you think I should keep doing TP scans until it shows up? |
New York,
New York
| Posted on Sunday, June 11, 2006 - 03:25 pm: |
Hey Gary... Well I not sure for the Ariza 700 but this is what I did for FLU... Menu > Installation > Antenna Setup...and select the ones you are using...I\\'m using Echo 7 and 8.6 Just use right (volume up key) to select it. Then.. Menu > Installation > Blind Scan...then I selected both Echo 7 and 8.6 by using right (volume up key) and ok to scan...and it usually takes a little while...like 5 mins or so... I don\\'t think I am missing any channels and PPVs and those affected by that ecm are working now. BUT...that is for Fortec Lifetime Ultra..I haven\\'t used the Ariza before...so I am not sure if the steps are the same. |
New York,
New York
| Posted on Sunday, June 11, 2006 - 03:30 pm: |
Ted Bone... HBOE doesn\\'t show up on your scans at all? I don\\'t know why that would be. Like I just did that TP scan to check and when I scanned Echo 7 TP2 ..HBOE does show up.. Ummm I am not sure why it\\'s not working.. Might need someone who knows a bit more to help with this problem... |
Post Number: 33 Registered: May-06
| Posted on Sunday, June 11, 2006 - 03:37 pm: |
i did as menu > intallation >antenna setup and select echo 7. echo 3 one by one then store this and exit then choose power scan and same as echo 3, i got only 195 channels. |
New York,
New York
| Posted on Sunday, June 11, 2006 - 04:03 pm: |
Hmmmm...I don\'t know why only 195 channels are showing up.. When I did my blind scan these were my settings.. Satellite Echo 7/KU Degree 119.0W LNB Config 11250 Symbol range Full Polarity All Scan All Satellite Echo 8.6/KU Degree 110.0W LNB Config 11250 Symbol range Full Polarity All Scan All And it scanned in all the channels. |
Post Number: 34 Registered: Jan-06
| Posted on Sunday, June 11, 2006 - 04:18 pm: |
It is the only channel i am missing. |
