Thread: CW 600 loading Problem pls help |
Bronze Member Username: Fortec16
Post Number: 19 Registered: May-06
| Posted on Sunday, June 11, 2006 - 10:09 am: |
I have a problem, which loader I used to load the bin file. I am using Computer has WINXP Home + serial port. Which cable should I use null/stright cable? standbymode mean --|-- right, and then I used the v1.05 uploader and the bin file v1.15. Nothinghappen. I did not changed any upgrade for 3months. Is that cause the problem? If you have uploader and file pls send it to me or tell me where do I get it? |
Bronze Member Username: Mrkvip
Phnom Penh,
Kandal
Cambodia
Post Number: 14 Registered: Mar-06
| Posted on Sunday, June 11, 2006 - 10:14 am: |
Hey, gus Go To dsstester*com Click on C**lsat File Download Coolsat_Pro_Loader 2.4 and New Bin is CCOLSAT6000_NORW_123_2006_06_10 Good Luck guy!! |
New member Username: Caco134
Toronto,
Ontario
Post Number: 1 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 03:32 pm: |
Hey guys, I have CW 600s and I need the new bin for fix it, where can I get it? thanks in advance |
Silver Member Username: Johnner
Miami,
Florida
Post Number: 206 Registered: Nov-05
| Posted on Sunday, June 11, 2006 - 05:21 pm: |
http://www.dsscentral.*net/files/uploads/Pansat6000-X-6095BL_060609_3122_E.zip |
