Thread: CooCoo 4000 Pro !!!!!!!!!!! |
New member Username: Rocks
Post Number: 3 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 08:54 am: |
Can anyone help me to find a the File for CooCoo 4000 pro. |
Bronze Member Username: Qbee
Post Number: 32 Registered: May-06
| Posted on Sunday, June 11, 2006 - 03:59 pm: |
Try here http://www.d**tester.com/files.php?cat=18 When you type in the url substitute "ss" for the "**" |
Bronze Member Username: Rocks
Post Number: 13 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 11:09 pm: |
qbee - i dont see any files for CooCoo 4000 pro please help me find . |
Post Number: 41 Registered: May-06
| Posted on Sunday, June 11, 2006 - 11:19 pm: |
Have you a C**lsat? (**=oo) I have never heard of a coocoo |
New member Username: Fatboy
Denton,
Nc
United states
Post Number: 1 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 11:53 pm: |
I have got a coocoo 4000 pro ,they say that the files wont go above a 1.10 for it that it would lock up the receiver,can anyone help me |
Post Number: 44 Registered: May-06
| Posted on Sunday, June 11, 2006 - 11:57 pm: |
hmmm - must be some clone c**lsat |
New member Username: Lumberman
Denton,
Nc
Usa
| Posted on Monday, June 12, 2006 - 12:04 am: |
hello i need help with a coocoo 4000. need file can any one help me please |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 881 Registered: May-06
| Posted on Monday, June 12, 2006 - 12:12 am: |
cooocooo is a weird, receiver with 0% support, if I can find any information I will post. |
Post Number: 14 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 10:15 am: |
Eva, Please help us to find the file i tried dowloading the Coo*sat 4000 pro 123 file and the receiver started to act funny , the receiver freeze and it has to be swicthed off from the back to reset but it keeps happening the same. help find a file |
New member Username: Fidarahman
Post Number: 1 Registered: Nov-05
| Posted on Monday, June 12, 2006 - 10:30 am: |
Hetre u go File Type: zip COOLSAT4000_NORW_123_20060610.zip |
Post Number: 15 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 10:43 am: |
Fida , I tried that already , i have mentioned on this please read , It DOESNT work. |
New member Username: Dopeyelf
Frampton,
Ont
| Posted on Monday, June 12, 2006 - 11:09 am: |
when you say its freezing, is it happening after you've been watching a channel for like 5 min, if so it could be because you have auto roll on, which caused the same thing to happen to my 4000pro. Also after updating make sure you do a factory set then rescan, it could possibly help. |
Post Number: 16 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 11:14 am: |
Dopey - I dont see any picture at all , the Auto roll is OFF - As soon as i swtich on the reciever without seeing any picture i have this problem, please help me on this |
Frampton,
Ont
| Posted on Monday, June 12, 2006 - 11:39 am: |
I think you will have to wait for a release for cools()t clones check out fta-clone.c*m to stay up to date . there are people there in the same situation. |
Gold Member Username: Lklives
Post Number: 3301 Registered: Jan-06
| Posted on Monday, June 12, 2006 - 11:44 am: |
coo*lsat clones files DO NOT exist anymore...not for past 7 months!...coo*lsat was first to put killer codes in bins to stop the clones! |
Bronze Member Username: Lada
Montreal,
QC
Post Number: 11 Registered: Jun-06
| Posted on Monday, June 12, 2006 - 11:51 am: |
LK help me please! I have Fortec Ultra, Uploader Bl 1.4,DB9 Cable- f/f serie 6pd 9f/9f. When I try Write Bin I have a message:Can not open serial port!!! Acces isdenied. What I need? Thanks. |
Post Number: 46 Registered: May-06
| Posted on Monday, June 12, 2006 - 10:55 pm: |
Rocky You needed the auroroll "on" to avoid the problem when you loaded the last 123 bin and you lost all channels about 5 minutes after flashing the stb. You also need to make sure your DiSeqC switches are right. |
Bronze Member Username: Etorres4u
Post Number: 28 Registered: Sep-05
| Posted on Wednesday, June 14, 2006 - 12:13 am: |
So anyone find any coo coo files yet? My neighbor invited us over for poker next weekend. It would be nice to have a use other than a doorstop. |
Puerto Rico
Post Number: 983 Registered: May-06
| Posted on Wednesday, June 14, 2006 - 12:16 am: |
My personal recomendation: Buy another satellite with better support. |
Bronze Member Username: Dixon_buts
Moon Base Alpha 1,
Red Square
Mars
Post Number: 37 Registered: Jun-06
| Posted on Wednesday, June 14, 2006 - 04:55 am: |
Lada you idiot phone up a friend and get them to do it for you. Even with the right advice you still get everything wrong. Did you unzip the file? Did you use BL-Updater 1.4.0.0? Are you using 277T? Are you using a straight through female to female 9 pin 232C cable? You said you found the right serial port and still fucked it up. Turn back switch on count 2 seconds then click on download or when you see something called nightrider lights when you turn it on from the back hit the download buttton. |
Post Number: 29 Registered: Sep-05
| Posted on Wednesday, June 14, 2006 - 11:45 am: |
I just read in other forums that the coo coo reciever is the same as a cooltech. Since there is as of yet no bin out for the cooltech, those that have a coo coo have to wait. As we all know cool*sat clones are having a pretty difficult time right now. There are coders working on the bin, but its not going to be easy. So if and when a clone safe bin comes out, remember to use the same bin as the cooltech 4000. |
Post Number: 3420 Registered: Jan-06
| Posted on Wednesday, June 14, 2006 - 12:02 pm: |
There are NOT cooltec coders working on new bins...NOT in past 7 months!...last November...if its not out now, it never will be!...all the DSS sites specializing in clones have stated this already! |
