Thread: EPG Loading screen |
Bronze Member Username: Nickb
New York,
New York
Post Number: 20 Registered: May-06
| Posted on Saturday, June 10, 2006 - 11:44 pm: |
Hi there... I have loaded the new 277T bin on FLU. But I have noticed that sometimes when I change channels..a channel that worked previously..becomes scrambled or bad channel. Then I have to do a power reset...then load the epg again until I get it back. Anyone having this problem? Also the epg on BV only loads for a few channels..it won\'t work for a lot of them on BV.. Anyway to fix that? Thanksss |
New member Username: Itguy
Post Number: 3 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 12:31 am: |
I have the same problem with Fortec Lifetime Classic NA. |
New York,
New York
Post Number: 22 Registered: May-06
| Posted on Sunday, June 11, 2006 - 12:40 am: |
Yeah I am not sure why it\\'s doing that. I just try to not change channels to quickly and that seems to limit it from becoming scrambled or bad. But it\\'s really annoying cuz once a channel becomes like that..I have to hard power off and wait for that epg to load again :S |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 814 Registered: May-06
| Posted on Sunday, June 11, 2006 - 12:48 am: |
Check the zone, date configuration. DElete all satellite and scan again, if you still have this problem post again. |
New York,
New York
Post Number: 23 Registered: May-06
| Posted on Sunday, June 11, 2006 - 09:06 am: |
Thanks Eva.. I will check those and rescan and let you know.. Thanks  |
Bronze Member Username: Aanaa
Post Number: 84 Registered: Mar-05
| Posted on Sunday, June 11, 2006 - 09:16 am: |
i had on pansat disabled auotroll |
Post Number: 4 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 01:22 pm: |
EPG FOR FORTEC LIFETIME CLASSIC NA WORKS NOW AS SUGGESTED ABOVE, I HAVE CHANGED THE TIME AND PUT THE TIME ZONE 'ON'. THANKS ALL FOR HELP. |
Bronze Member Username: Bthitman
Post Number: 11 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 01:29 pm: |
Nick,how did you get your scrambled or bad channel back ? |
New York,
New York
Post Number: 24 Registered: May-06
| Posted on Sunday, June 11, 2006 - 01:41 pm: |
W T... I just turned the reiceiver off and then on again..and ran the epg ..waited for it to finish. Then everything was fine again. Eva... I tried deleting nimiq1 and rescaned it but I still don\\'t get guide for a lot of BV channels. Is your guide working ok for BV? Thankssss |
Post Number: 12 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 02:01 pm: |
Thanx Nick. I'll do the same. |
Post Number: 7 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 02:26 pm: |
Nick, You mentioned that you turned off the reciever off and after turing on, you ran the epg. I have a Classic NA but dont see any option to run the the epg? Basically, i want to get all the international and ppv channels. I have the correct bin file and code but still i get 'scrambled channel' after a while it says 'please wait code updating' and then again goes 'scrambled channel'. Any suggestions? I have already tried reloading the bin, rescanning Echo1-2 and 7. |
New York,
New York
Post Number: 26 Registered: May-06
| Posted on Sunday, June 11, 2006 - 02:34 pm: |
Hey Sam Pat.. For my FLU receiver I loaded the X-85BL_060610_277T_au_api bin.. And on startup there is a splash screen that says \\'EPG loading..\\' and gives you options \\'OK or Exit\\'. I am not sure for Classis NA...but Echo 7 and 8.6 are both working for me. I didn\\'t get the \\'Please wait code updating\\' message. Maybe someone who knows more about the Classic can help here.... Anyone have any ideas? |
